For the longest time I had a ATI TV Wonder VE Card and Liked it very much, however I was given a ASUS V7700 Pro Deluxe and switched to that, giving away the TV Wonder. I had captured some clips from a camcorder with the ATI card and used a compressed format to cut the file size down, now I cann't view the video in the clips and the ATI Video codec refuses to load (I guess I need the card).
Is there any software fix where I could convert it to mpg, or view it and send it to a tape or dvd. I really need to get to these clips as one of the persons on the clips pass away Jan 1.
any help
The software is unfortunately the ATI Multimedia Center. You would need to bring up the Library application and browse for the VCR file, right click it and select "Convert To MPEG-2". I've never had any look playing VCR files withough all the ATI drivers and software installed. In fact I stopped capturing to VCR a long time ago for compatibility reasons. Maybe you could put your clips on a CD and take it to the person who has the card now. Or perhaps you could try installing ATI MMC again(no idea if this will work) and see if the Library app will start so you can convert.
Well, you could one of these CODEC's, but you'll have to search for them
on google, or one of those CODEC websites (can't remember where though)
Just search for the filename.zip and ignore everything else to the
left (its just my way of organization) below:
(Codec) - (VCR1) - (vidc-vcr1) - (like I263) - (hack - based on YUV9) - Ativcr.zip
(Codec) - (VCR2) - (vidc-vcr2) - (YUV12 plannar) - (hack) - Ativcr.zip
The above are codecs that allow a person to view files encoded, though they
do not allow you to Encode to them
But, once installed, you can load the .avi files inside vdub and view them
or edit or whatever.
-vhelp
I Installed MMC for XP and that didn't help, the other reply I got, I down loaded the file and that didn't work. I would appear that the VCR1 codec is not getting loaded, the VCR2 one is. Any more ideas?
Gary
Update: one can NOT view a vcr1 file on a XP system, the video file needs to be converted before switching to Windows XP.
Video goes to snow with ATI Theater 650 pro capturing through s-video
By Des in forum CapturingReplies: 5Last Post: 26th Aug 2010, 07:37 -
ATI GPU-accelerated codec
By cheerful in forum Software PlayingReplies: 1Last Post: 10th Jan 2010, 09:19 -
Upgrade video card to ATI HD4670
By hulinning in forum Media Center PC / MediaCentersReplies: 2Last Post: 9th Jan 2009, 19:55 -
VGA - S-video with ATi x1400?
By conory in forum Media Center PC / MediaCentersReplies: 5Last Post: 21st Jun 2008, 19:53 -
Any Video Capture Software for ATI Theater 550Pro?
By quantass in forum CapturingReplies: 1Last Post: 8th Sep 2007, 18:26
