I noticed that on the odd occasion when I put a DVD-R into my drive that the icon doesn't appear on the desktop but I can play the disc. The only way to make a copy of this disc is to do a direct copy in toast but I like to have the files also backed up on my hard drive. is there any way of extracting the files once copied into toast? or is there another solution to this problem?
Thread: Problems backing-up some DVDs…
Do I just save it as a disc image?
and if so how do i burn it then?
you got it
FILE / SAVE AS DISK IMAGE
the image can then be burned and it can also be mountd later on if you need to access the files again
Thanks - that worked.
excellent
Just out of curiosity, are you running a screensaver as your desktop background? Some implementations of that cause discs to not be mounted normally. Xback solves that problem, if you still want to run background screensavers.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systčmes, le cas d'application excepté."
No, I don't bother with screensavers
Hi, folks.
I've got, roughly, the same problem with a dvd-r that I'd burned a few months ago. Unfortunately I can't get it to play on my iMac 17" G4 running OS 10.2.8. It'll play on my Sony stand alone player, but I need to do some editing of the files, and nothing is recognized by the computer. Any suggestions?
Thanks,
Drake
Problems backing up DL dvds using DVD Shrink and ImgBurn
By ManuBumb in forum Newbie / General discussionsReplies: 9Last Post: 7th Apr 2009, 21:35 -
Backing up my dvds and the chapters are scrambled?
By Ronja in forum Newbie / General discussionsReplies: 1Last Post: 5th Oct 2008, 16:22 -
Weird issue backing up DVDs
By downer in forum DVD RippingReplies: 6Last Post: 26th Aug 2008, 13:40 -
Backing up RedBox DVDs?
By punkhop in forum Authoring (DVD)Replies: 1Last Post: 29th Aug 2007, 20:28 -
'backing up' dvds
By nobbyiscool in forum Newbie / General discussionsReplies: 3Last Post: 13th Aug 2007, 20:25
