I don't really understand the difference between divx and avi could that have something to do with the following:
With a divx player are you supposed to be able to play divx movies without even encoding or converting them. I've tried with my new one I bought today and I am getting no where the only ones that will play are the mpeg encoded ones. The reason why I got it in the first place was to forget about the virtualdub and tmpgenc. Any ideas? Plse get back to me if you know something. Ta in advance. You've been great up to now grovel grovel :P :P
avi is just a container for several video formats like dv, divx, mjpeg, xvid etc. Your player does probably only support divx4+ and maybe xvid. You can check with gspot what kind of avi video it is.
And check our dvd player list for more info about your player.
Thanks for clearing up the doubt I had surrounding the avi. However it's a DIVX file, if I burn it to disc shouldn't I be able to play it in its original format? This I can't do and it supports xvid dvd everything it's a multiplayer apparently
mebbe this link might have some cluhttp://vcdrookie.com/eng/index.php?option=tools&task=viewarticle&artid=18&I temid=57es:
burning divx files as data to play on dvd player
By penguyen in forum Authoring (DVD)Replies: 4Last Post: 30th Jul 2011, 10:54 -
How do convert Divx files to play on my DVD player?
By Solehawk in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 19:37 -
Why does this mpg file doesn't play sound in my divx player?
By Stealth3si in forum Newbie / General discussionsReplies: 15Last Post: 5th Jul 2009, 19:00 -
Can I play HD divx files on a NON-BlueRay Player (DVP-5990)?
By DVantrease in forum DVD & Blu-ray PlayersReplies: 17Last Post: 20th Nov 2008, 15:18 -
Media Player Classic can no play DivX files
By siluet in forum Software PlayingReplies: 6Last Post: 30th Sep 2008, 15:46
Statistics
Newest guides
Latest tool updates
New media comments
