Can anybody help?
I have burned a movie onto disc,verbatim[dvd-r 4.7gb]using deep burner.This plays fine on my computer[sony vaio ]but when i play it on my stand alone dvd player,a sony[dup/ns305]a message appears saying [cannot play this disc]Can you advise me of the correct disc's to buy that would be compatible to play on my stand alone dvd player.
Any info would be received gratefully.
Results 1 to 9 of 9
Check your player in the compatibility chart on the left. Sonys are notorious for not liking burnt disks.
Thanks richard,thats the first thing i did yesterday,
It never really gave a difintive answer,i guess that's the nature of the beast.
Thanks to you as well stillmars,i was going along those lines myself.Cheers.Any more info is welcome!
My bro has a sony and its picky as hell with media.
Can you try in a friends dvd player or on a ps2 or something to see if it works.
You just gotta try and work through all the possibilities. If it dont play on any player try the same discs burned with a different application. If it plays on another player then the sony may not like that media...trial and error until you find what works for you i am afraid.
Good luck."Pull your tongue out of my ar$e hole Gary...dogs do that. Your not a dog are you Gary?"
"Err no...."
"But you do have all the characteristics of a dog Gary...all except loyalty."
Oh and for the record my bros machine is an ns300. We have used ritek and bulkpak burned with nero 6 with 100% success rate..but LONGTEN001 media would not play reliably at all.
Hope this helps a little"Pull your tongue out of my ar$e hole Gary...dogs do that. Your not a dog are you Gary?"
"Err no...."
Thanks bricktop!
Like the spec's on the pec's
Not that im that way inclined
i'll keep tryin till i find the right kind.
LOL thats not me mate...got a little way to go.Thanks bricktop!
Thats Steve Reeves....old school (1940s) BBing champ...prefer the classic physique of old."Pull your tongue out of my ar$e hole Gary...dogs do that. Your not a dog are you Gary?"
"Err no...."
No sound when playing playing burned DVD on stand alone player
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2010, 13:11 -
.SRT Font Size When Playing Using Flashdisk On Stand-alone DVD Player
By randy3101 in forum SubtitleReplies: 5Last Post: 9th Apr 2010, 00:48 -
DVD Player problem playing .avi
By dexter30 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 17th Sep 2009, 00:18 -
Problem With Stand alone DVD player and Burned Dvds
By tealmarlin in forum Newbie / General discussionsReplies: 6Last Post: 25th Jan 2009, 14:02 -
Problem with playing DVD in standalone player
By tngolfn in forum Newbie / General discussionsReplies: 2Last Post: 14th May 2007, 17:41
