Do you pros recommend disabling the windows xp burning software in order to use other burning software? Ive been having some problems. Can anyone help me out? I bought the Jasc Paint Photo album 4.04 so I could play around with my digitals and burn them to vcd in their program. At first it worked pretty good but now it only works if I uninstall my cd burner from device manager and let it reinstall after rebooting. Ive replicated the problem 3 or 4 times. Thats the only way I can get it to work. Is it possible some other burning software or the xp built in burning software is conflicting? The only other burning software I have installed is musicmatch. Anybody got any ideas.?
P.S I couldnt get Nero or Roxio to work either. Thanks Much Bob
Closed Thread
Probably a dumb burning question
By neroguy in forum Newbie / General discussionsReplies: 14Last Post: 7th May 2011, 04:34 -
Dumb PS3 Question
By wulf109 in forum DVD & Blu-ray PlayersReplies: 10Last Post: 4th Feb 2009, 07:56 -
Really dumb USB 1.1 Question
By ahhaa in forum ComputerReplies: 4Last Post: 1st Jan 2009, 15:50 -
Remove noob newbie or dumb from Subject line?
By Supreme2k in forum FeedbackReplies: 5Last Post: 6th Jan 2008, 08:13 -
Dumb question about 768p
By winterwolfes in forum DVB / IPTVReplies: 28Last Post: 2nd Jan 2008, 16:50
