Using SVCD2DVD, when i try to add a particular movie either from it's cue/bin or from an mpg, I get en error:
An unhandled exception has occurred in your application............
Cannot perform the requested operation on an item that exists.
Type Xceed.FileSystem.DiskFolder
************** Exception Text **************
Xceed.FileSystem.ItemAlreadyExistsException: Cannot perform the requested operation on an item that exists.
Type: Xceed.FileSystem.DiskFolder
FullName: ***blanked this bit out***\
at Xceed.FileSystem.FileSystemItem.set_Name(String value)
at _S_VCD2DVDMPG.210ff09a2516b1a7.e539963764b40d25(St ring 8dd66a714110d48d)
at _S_VCD2DVDMPG.210ff09a2516b1a7.60f18f1e09a87437(Ob ject e0292b9ed559da7d, EventArgs fbf34718e704c6bc)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventAr gs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage (Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(M essage& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.573
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
SVCD2DVD
Assembly Version: 1.51.2.0
Win32 Version: 1.51.2.0
CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD/SVCD2DVD.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
Xceed.FileSystem
Assembly Version: 1.0.29.0
Win32 Version: 1.0.29.0
CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD/Xceed.FileSystem.DLL
etc..etc...
Any help please?
OK, scratch that - i moved the cue/bin files to a different drive and put them in a folder called TEST - seems to be working fine now - maybe it's a problem with path name/lengths??
it is a problem with some path names. If there is a hyphen in the path it will be rename to be an underscore. Sometimes this is prevented by windows. If this is the case the renameing the relevent folder manually will do the job...
SVCD2DVD crashes, HDTV2DVD runs ok
By silicon101 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 11th Jul 2011, 15:32 -
Windows 7 Ultimate - Can't load assets in SVCD2DVD
By ttyner in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 13th Jan 2010, 10:54 -
SVCD2DVD 2.5 Will Not Load
By Rower4VT in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 2nd Sep 2009, 13:25 -
DVD does not load
By joelson in forum Newbie / General discussionsReplies: 4Last Post: 26th Dec 2008, 09:23 -
SVCD2DVD 2.5.3100.0 Crashes
By boggle in forum SVCD2DVD & VOB2MPGReplies: 16Last Post: 11th Sep 2007, 03:34
Statistics
Newest guides
Latest tool updates
New media comments
