VideoHelp.com Forum
  1. Just curious about how much "overhead" there is when creating a new session. For example, how much space is used for lead-in and lead-out.
    I ask, because I have some files I wish to burn to a DVD+R disc, but I don't have enough to fill the entire disc. I'd like to add more at a later date if possible?
    Nero 6 warns me that multisession discs aren't supported by some DVD-ROM drives, and also that only Windows XP supports them. Is this true? I'm using Windows 2000. Would I run into problems, even if I used the DVDRW drive to read the discs?
    TIA
    Not actually sure about that.
    But if you have a RW around, try a few tests!
    Burn a few sessions. See if win2k handles them okay.
    Possibly try burning a series of 500MB sessions. Check if the reported/actual size is off by alot (to measure leadout).
    Can't do any harm since they are rewritable discs
    Aggies
  3. Good idea. I just wondered if anyone *knew* before I start messing with my RW discs (s'pose I can always use the one that came with the drive!)
    *UPDATE*
    Well, I can confirm that it all seems to work, and much better than expected.
    Nero reports the file system overhead as 300 KB approx. (this is only for a couple of files, but still...)
    The Disc Info option pops up a list of sessions, but even though I have done 2 separate sets of files, they show up as a single session, which is a good thing I assume.
    And Windows 2000 has no problem seeing both "sessions".
    However, I do have to eject and re-insert the disc after burning for some reason...
    *UPDATE 2*
    Windows 2000 seems to get a little confused with multi-session DVD discs, and will only show the capacity and used size as that of the last session...
  4. Member garryheather's Avatar
    I think in the CD-R domain it's a Meg or two per session plus something like 5M for the first one to allow lead-in / out, but I don't know the approximate figures.
    I doubt DVD-/+R is much different. The procedure isn't all that different either.
  5. Yeah, I thought it'd be similar to CD-Rs. I just heard somewhere that the overhead was about 200 MB :/ (because you can't fit 4700 MB on a DVD or something - maybe because 1 GB isn't 1000 MB?)
    Woh, heh, overhead should definitely not be *that* much
    DVD's sizes and hard-drives are both listed incorrectly mainly due to marketing reasons. For them, one GB is considered 1 Billion bytes. When in reality 1GB = 1073741824 Bytes (1GB = 1024MB, 1MB = 1024KB, 1KB = 1024 bytes ...) So when you list something using *their* math, they always turn out to be a bit larger...
    So each DVD/Harddrive GB is short by about 70MB. The 4.7 actually works out to be around 330MB short, leading to an actual capacity of 4.37GB or 4480MB
    Aggies
  1. Low overhead streaming server software
    By Sierraguy in forum Video Streaming
    Last Post: 7th Jul 2010, 23:55
  2. xvid - how to calculate avi-overhead?
    By Information in forum Video Conversion
    Last Post: 9th Nov 2009, 07:35
  3. How much are DVD multiplexing and subtitle overhead?
    By fvisagie in forum Authoring (DVD)
    Last Post: 10th Jul 2009, 11:35
  4. Need to video from OVERHEAD...i.e. a Piano.
    By Gromit137 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 17th Oct 2007, 10:45
  5. Taking Video from Overhead..i.e. Piano.
    By Gromit137 in forum Newbie / General discussions
    Last Post: 15th Oct 2007, 13:48
