Hello,
I've been converting my downloads as a DVD mpg file and then using TMPEGnc Author to burn on a DVD. It's been working great with the following exception:
Whenever I try to convert an AVI file which is usually has the following info XVID [bt-gm] [EFnet] and is a 23.97fps file, it locks up the TMPEGnc program. I've tried converting to DVD, VCD and SVCD, all with the same results. No other file gives me a problem. I'm sure I have all the proper codecs but I always check with G-spot to make sure. It says I have the codecs.
Can anyone tell me why I'm having this problem? Why are these paticular avi d/l always at 23.97fps??
Any help I can get on this is appreciated.
Thanks,
Thread: TMPEGnc HEP w/ 23.97fps and AVI
I've never been able to get TMPGEnc and XviD to play nicely together.
Anytime i use TMPGEnc with XviD source i change the FourCC from XVID to DIVX.
AVI FourCC code changer:
http://inmatrix.hoyty.com/mirror/avic100.zip
Another thing you could try is loading the XVID into VirtualDub and frameserving to TPGEnc. May be a little slower but should work. Also would give you the oppurtunity to take advantage of some of VirtualDub's filters if you choose w/o having to do full encode from XVID to soething to MPG in TMPGenc.
Everybody talks about "frameserving" can somebody please tell me what that is!!!!!!!!!!!! :P
Sorry to be a muppet!!!
I had exactly the same problem. After realising that the audio was AC3, something that TMP cannot understand, I used Goldwave to convert the audio to standard wav.
All I did was load the original file into goldwave and save the audio as stereo.
TMP then accepted the file, hope this helps
Mark
25 or 29.97fps?
By pooksahib in forum Video ConversionReplies: 6Last Post: 16th Jan 2011, 16:54 -
Nero Won't see my DVD Burner !!! HEP ME HEP ME!!!
By THE_oldguy in forum DVD & Blu-ray WritersReplies: 14Last Post: 24th Dec 2009, 11:07 -
avi is 23.97fps,srt is 25fps
By Soixante in forum SubtitleReplies: 7Last Post: 3rd Dec 2008, 14:26 -
AVI File Not Supported by TMPEGnc?
By The Monkees in forum Video ConversionReplies: 5Last Post: 3rd Feb 2008, 18:26 -
why 25fps avi or 23.97fps avi
By theewizard in forum DVD RippingReplies: 8Last Post: 12th Jun 2007, 08:03
