can you disable autopadding in vcdeasy?
No you can't.
Firstly, VCDEasy doesn't do the autopadding. VCDImager (the underlying guts of the program) does.
Secondly, autopadding if required is necessary to make the image. Basically, autopadding is required when the source MPEG streams aren't multiplexed correctly.
If you don't want VCDImager to autopad your streams (you don't) then you should make sure that your MPEG files are correctly multiplexed to begin with (i.e., with remultiplex with either TMPGEnc on the MPEG-1 Video-CD setting or with bbMPEG).
Regards.Michael Tam
w: Morsels of Evidence
That's right. Autopadding can increase the image size by as much as 40%, which drives me crazy. Re-mux is a must.
how do you do the re-mux in tmpgenc?
File --> MPEG Tools --> Simple Multiplex.
For standard VCD, change the setting to "MPEG-1 Video-CD"
For non-standard/XVCD, change the setting to "MPEG-1 Video-CD (non-standard)"
For SVCD, change it to the obvious setting.
Select your input and output filenames of course.
Best regards.Michael Tam
Not to rain on anyone's parade, but the "official" guide is here: http://www.vcdeasy.org/modules.php?n...es&id=VcdTrick
It sure helped me out, when VCDEasy kept padding my VCD's, making them unplayable. Now I run every VCD through TMPGEnc's mux and haven't produced a coaster in months.Cheers, Jim
My DVDLab Guides
How do you disable UAC for just VOB2MPG?
By Wakewatcher in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 18th Jan 2011, 11:10 -
Disable HDMI audio
By JOHNINA in forum DVD & Blu-ray PlayersReplies: 5Last Post: 28th Feb 2010, 09:58 -
How to disable a DVD button?
By dexter30 in forum Authoring (DVD)Replies: 2Last Post: 23rd Feb 2010, 17:27 -
Disable Forward
By modtec in forum Software PlayingReplies: 2Last Post: 27th Jan 2009, 11:46 -
Cannot disable DVD subtitles
By Talayero in forum SubtitleReplies: 8Last Post: 8th Aug 2007, 16:56
