Results 1 to 9 of 9
  1. Hi !
    I have a Philips DVD 751 player!
    Does anyone know where to find a list
    with p-codes and some description how
    to use it?
    I recently have firmware 7.03 and p-code 054 (P54)
    and I want to view SVCDs
    Thanks!!!
    Med.
    If you checkout the DVD PLayer compatibility list you will find useful links for "hacks" and comments made by other users.
    Here the quicklink
    http://www.vcdhelp.com/dvdplayershac...ilips%20DVD751
  3. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
    On 2001-07-11 06:07:19, Medical wrote:
    Hi !
    to use it?
    Thanks!!!
    Med.
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    I also have the Philips DVD751...with the same firmware version but p-code 33.
    I was wonderiing if anyone can tell me what do I gain by upgrading the firmware to 7.12 or 7.22? and what pcode P33 means?
    Thanks,
    Joe
    Try 055 (r2, pal, svcd ok) !!!
  5. Hi lapin !
    It seems to me as if you are the most competent
    person regarding p-codes
    Please tell me how to enter the various p-codes
    (do I need a special remote control) and if
    there is any disadvantage comparing to p 054!
    THANKS A LOT!!!
    Med.
  6. Oh, I forgot...I just upgraded to firmware 7.22!!!
    Upgrade worked without any problems.
    There is two ways to change the p-code :
    the best one : with a rc6 remotecontrol (oneforall, pronto or a palm. you have to edit a rc6 code (4235). Then you have to play : RC6 055 000 000 000 play (with the original remote)
    the other way, with the original remote : play 159 055 000 000 000 play (attention with this way you can just enter 25 times a new p-code, that's why the first method is better).
    The 055 p-code gives you all functions but it's r2 and pal (if your player is regionfree, you'll loose this ability).
  8. Hi lapin!!!
    Thanks again for your reply!!!
    (I was on holiday this weekend,
    that's why it took me so long
    to reply!)
    I entered the p-code with my
    original remote for I don't
    have any idea what a rc6 code is.
    Entering the p-code was no problem
    - thanks to you
    What's the diffrence between the
    054 and the 055 p-code?
    You mentioned that I can only enter
    this code 25 times. Do I have to
    enter it somewhen again or is it
    now "stored" in my player like the
    new firmware I loaded?
    T*H*A*N*K Y*O*U
    Med.
    You're welcome Medical,
    You don't have to enter the p-code each time you change disk, it's stored in your player (whatever firmware do you have).
    The only difference between 054 and 055 seems to be the beeper and the 6 audio chanel...
    Ciao
  1. how to hack region code for dvd player philips pet1031
    By HAMAD111 in forum DVD & Blu-ray Players
    Last Post: 8th Nov 2008, 03:21
  2. Region code hack Philips DVD 743 ?
    By Zen in forum DVD & Blu-ray Players
    Last Post: 18th Jun 2004, 12:54
  3. Philips Error Code
    By asichter in forum DVD Recorders
    Last Post: 23rd Feb 2004, 15:12
  4. philips mx3700d code
    By oswaldofm in forum DVD & Blu-ray Players
    Last Post: 16th Dec 2002, 16:05
  5. Conversion of Philips 722 DVD Player to Region Code Free
    By The Rising Hope in forum DVD & Blu-ray Players
    Last Post: 5th Dec 2001, 23:39
VSO Software ConvertXtoDVD lets you convert any video like AVI,MKV to DVD easily. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
