VideoHelp.com Forum
  1. My capture program (WinDVD) captures directly to mpeg for the audio, and for whatever reason the sound quality and volume fluctuates a little. (The reason I'm using WinDVD is that I don't have the time to capture to AVI and convert, and this is the only mpeg-2 capture program I have).
    Anyway, I was wondering if it would be possible to simply capture the audio seperately in another program (probably as a wave), convert it to AC3 (as I normally do), and then combine it so that it syncs with my video file?
    I would imagine the audio and/or video would have to be trimmed as you wouldn't be able to start the two captures at the same exact moment.
    Thanks in advance.
  2. I think audacity (free) will record a wav file....
  3. I'm a Poll Super Moderator johns0's Avatar
    Most likely the audio will be out of sync if you use another program to capture sound,you`ll have to either stretch or shrink the audio to match the video length so its best you find a capture program that works or fix the audio the way i described without having to capture audio twice,just fix the original audio track.
    I tried this once just to see if it worked OK. I used ATI MMc for mpg2 and Audacity for the audio. Technically it worked but trying to sync later on was a bit of a nightmare. I wouldn't recommend it unless you have no option.
  1. Capturing audio
    By kschwi in forum Audio
    Last Post: 25th Apr 2012, 12:13
  2. Canon HFS100 + recording audio seperately
    By intellijel in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 10th Nov 2009, 11:00
  3. Editing the audio seperately?
    By extremebeat in forum Editing
    Last Post: 5th Feb 2009, 17:21
  4. Replies: 3
    Last Post: 29th May 2008, 08:22
  5. how to prevent generating video and audio file seperately?
    By mzhang in forum ffmpegX general discussion
    Last Post: 29th May 2007, 08:42
