I can't hear any audio when played back on my DVD player. Everythings fine when payed on the computer. Any Ideas?
how did you encode the audio?
I'm a Newbie and really haven't learned how to do that yet. I used TMPGenc to join the two Mpegs and then used Easyvcd to burn. The video part is fine. I have been investigating and understand the problem could possibly be in my DVD player's setup. I will try to switch to analog pcm?
That is if I can figure out how to do it. Do you think that will work? Thanks for the reply
so I take it u downloaded the mpg files then? goin by what u said.
Hi, Sorry for the delay, just returned to town. Yes, I downloaded the mpegs. What do you think the problem might be?
what it could be is wrongly encoded audio, sure it will play fine if ur computer has the right codec installed.
what I suggest is run the mpg files through tmpgenc as whatever format they were burned as makin sure ur usin correct frame rate eg: 23 fps = NTSC 25 FPS = PAL
see if that helps.
Finally... my new film has been released!
By _Max_ in forum Newbie / General discussionsReplies: 4Last Post: 18th Dec 2011, 13:47 -
Lightworks Beta is finally out!
By Milardo in forum EditingReplies: 9Last Post: 6th Mar 2011, 10:31 -
finally my mac
By scarlac in forum DVD RippingReplies: 5Last Post: 23rd Apr 2010, 02:54 -
BD+ finally cracked...
By ntscuser in forum Latest Video NewsReplies: 12Last Post: 25th Nov 2007, 07:14
