VideoHelp.com Forum
  1. Hi
    I have a question. I'm burning a VCD.I have couple of movies which I recored earlier from my Digi Camera.Then I converted the mov. format to Mpeg with PAL system. After I've done the procedure I was curious if it's gonna work in a NTSC DVD player.And it did. So i was surprised that I changed the format and it still worked nin my NTSC player. Does it make any diffrenece if i change the format while I record a VCD ?
    Thx
    Perhaps you have a multiformat DVD player that can convert PAL to NTSC on the fly...or perhaps you have a multformat TV that automatically switches between NTSC or PAL based n the input signal
    No, I'm from Iowa. I only work in outer space.
  3. Member akbor75's Avatar
    as far as i know, pal / ntsc refer to the analog signal of the movie. so if you're talking about mpeg's, there is in fact no pal / ntsc format.
    i think an "ntsc dvd" is in fact a region 1 dvd. but if you burn it yourself there's no region, so no problem.
    (i'm no pal/ntsc expert, so correct me if i'm wrong.)
    Music was my first love, and it will be my last
  4. Member bugster's Avatar
    Largley correct except for this:-
    an NTSC DVD will be encoded with 29.97fps and the full D1 resolution is 720 * 480.
    a PAL DVD will be encoded with 25fps and the full D1 resolution is 720 * 576.
    A DVD player that can handle both PAL and NTSC (which is most) will output NTSC (analog) signals when it sees a DVD that matches the 1st description above and output PAL (analog) signals when it sees a DVD that matches the second.
    Some players can take either format and convert internally to PAL or NTSC (though how they handle framerate differences I don't know)
    The framerates don't change. Only the color system does. One of my output devices is an Epson EMP-50 LCD projector that has a portion of the menu that states detail about the detected sync rates of the input signals. Even if NTSC>PAL option is chosen on the DVD player which has an NTSC disc in it the H and V values remain the same so it means the framerates didn't change. Interestingly it also shows whether progressive scan signals are being received: for NTSC H is 15.734KHz interlaced and 31.469KHz progressive.
    M: Bond, I want you back.
    James Bond: I never left.
    This is known as PAL60.
  7. The Old One SatStorm's Avatar
    There is also the opposite: NTSC 50.
  8. Member bugster's Avatar
    Just for interest
    Ok, so those forum members from the USA that own DVD players that 'convert PAL to NTSC', does this mean they output NTSC-50 and if so, do most US TV's accept this kind of signal?
    I know many (most?) European TV's handle either NTSC or PAL-60 (as well as PAL), if not both (all) formats.
  1. when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
    By spiritgumm in forum Video Conversion
    Last Post: 13th Oct 2011, 12:57
  2. How to make DVD in PAL and NTSC?
    By perik in forum Authoring (DVD)
    Last Post: 19th May 2010, 14:18
  3. PAL to NTSC, NTSC to PAL framerate conversion?
    By Baldrick in forum Video Conversion
    Last Post: 5th Dec 2009, 23:31
  4. hdr sr12(NTSC) or hdr sr12e(PAL) any difference between them?
    By deejay.2001 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 26th Aug 2008, 16:28
  5. NTSC to PAL, PAL to NTSC framerate conversion?
    Last Post: 23rd Apr 2008, 11:19
