VideoHelp.com Forum
    Hi Folks,
    I will be sending some PAL dvd's to my friend in USA.
    He has an Lasonic DVD 1100 player, and says it can play back PAL \ NTSC
    his TV being the standard NTSC.
    Question ? does anyone know if the DVD player is set to playback in PAL
    mode will it convert it automatically to NTSC for the TV ?
    Regards
    Mack........
    Most DVD players can handle either format. Virtually all TVs in the US are single standard (NTSC). Your friend will most likely have to watch the DVDs on his computer.
    ICBM target coordinates:
    26° 14' 10.16"N -- 80° 16' 0.91"W
    Oh, and the DVD player will NOT convert the signal, unless you have a player that can convert standards (again, not very many of those over here).
    Standard converting players do exist, but they cost more, and are more likely to be found in the lesser developed countries like France and Zaire.
    HI SLK001,
    Thankyou for your reply, at least I have some idea now if
    it will play back or not on his TV.
    Best Regards
    Mack.....
  5. Toshiba sd4900 and most JVC players have built-in PAL to NTSC converters. Some cost less than 100 bucks. You can check here for more info on different models.
    http://www.dvdrhelp.com/dvdwriters
  1. Convert PAL Signal to NTSC for USA HD Plasma
    By hilite in forum DVB / HDTV
    Last Post: 25th Aug 2011, 06:11
  2. Will the tv convert the signal from 1080p to 1366x768 ?
    By ivade-ragnarok in forum Newbie / General discussions
    Last Post: 21st Nov 2009, 00:34
  3. Replies: 13
    Last Post: 7th Dec 2008, 14:20
  4. Replies: 8
    Last Post: 17th Oct 2007, 06:05
  5. Replies: 1
    Last Post: 8th Jun 2007, 20:42
