VideoHelp.com Forum
  1. there is a dvd I want to buy, but it is only available on dvd in australia and is region 4
    if my stand alone will not play it
    what would be the best way around this problem?
    thanks
  2. Member mats.hogberg's Avatar
    Rip it. Most rippers/transcoders are set to remove RPC as default.
    /Mats
  3. i have a DVD of an English Movie
    i don't know its region
    my DVD ROM is set to region 1
    what should i do to see the movie
    drive accesses the disc but can't play or browse for vob files
    please help
  4. if you want to watch it on your computer;
    1) rip it with dvddecrypter in iso mode
    2) mount iso through daemon tools
    3) watch with your dvd playing program of choice (i suggest powerdvd 4/xp)
    if you want to watch it on your standalone transcode the dvd to dvd5 and burn.. if its already a dvd5, just rip it to an iso and burn it with recordnow max.. your standalone/tv may not play it if it is not the same tv type that you have (pal/ntsc)
  1. cannot change region code from 1 to 2
    By decocal in forum Software Playing
    Last Post: 16th Oct 2009, 04:27
  2. Can't change region code
    By The-One in forum Blu-ray Ripping
    Last Post: 22nd Mar 2009, 11:19
  3. Need to change Region Code for NEC NDRV-60
    By alexspag in forum DVD & Blu-ray Recorders
    Last Post: 11th Dec 2008, 08:19
  4. HOW DO YOU CHANGE REGION CODE ON A PSP (playstation portable)
    By true_red_devil in forum Newbie / General discussions
    Last Post: 20th Mar 2008, 06:03
  5. how do i change the region code on a psp (playstation portable)
    Last Post: 19th Mar 2008, 16:07
