Hi
How can I create one subtitle file (*.srt) from 2 subtitle files that are *.srt's?
I tried to use srt2sup and did:
SRT Files -> Open as text (Loaded first subtitle)
SRT Files -> Append as text (Loaded second subtitle)
- Selected ALL subtitles -
SRT Files -> Save as text list.. (Saved as *.srt)
But when I test it the second subtitles just don't play in the movie that I've already joined, it was also in 2 files.
Did I do something wrong? Is there another way? Subtitle Workshop?
Ty,
Tiago Cabaco.
Subtitle workshop is the best sulution...off corse rhe second part of the sub will be out of sync, i think its normal...at least that happens to me often...
hum.. ok
but it would help a lot if you told me how you do it..
Hi,
What you did should work fine!
Can you explain in more detail what did not work?
Regards
Srt2Sup
Convert XML to SRT subtitle file
By subsync in forum SubtitleReplies: 6Last Post: 30th Mar 2012, 16:39 -
How to position a subtitle in a .srt file ?
By momo1984 in forum SubtitleReplies: 3Last Post: 26th Feb 2011, 06:43 -
Can't input a subtitle file (SRT) to Xvid4PSP
By mahogany in forum SubtitleReplies: 3Last Post: 26th Mar 2010, 07:01 -
Subtitles Tools (SUB to SRT 1.33) for OCR Chinese Txt to SRT
By dennis3377 in forum SubtitleReplies: 0Last Post: 10th Dec 2009, 00:46 -
how to convert an .idx subtitle to a .srt file??
By vinayak1986 in forum SubtitleReplies: 1Last Post: 9th Sep 2007, 11:53
Statistics
Newest guides
Latest tool updates
New media comments
