VideoHelp.com Forum
Results 1 to 12 of 12
  1. hi ive tried different discs ive tried burnind with nero 5.x.x.x..
    nero 6.x.x.x recordnow 4.60 and dvd dycrypter 3.190. in all aspects of burning software i use. i never get past the lead in stage of burning, so therefore i get no coasters... so what is a power calibration error.. i checked all the posts in the forums and everyone seems to blame bad media. if its a dvd9 i decrypt with dvd decrypter and shrink with dvd2one and tried burning with all softwares ..if a dvd 5 i decrypt with dvd dycrypter and burn iso from there same probs with nero and record now ??????????
    LITE-ON DVDRW LDW-811S> Version: HS06
    i have never to date succeded in burning a dvd. please someone help .dont say bad media , because i cant even get past the lead in stage of burning ... thanxs v much
  2. Lost Will Hay's Avatar
    .........dont say bad media , because i cant even get past the lead in stage of burning
    Bad media.
    Didn't work for me until I switched brands.
    How many different types of DVD-r have you tried?
    Will
    tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
  3. HAVE YOU GOT THE LATEST VERSION OF FIRMWARE FOR YOUR DRIVE AS THIS OFTEN OVER COMES PROBLEMS WITH MEDIA USE THIS LINKhttp://forum.rpc1.org/portal.php TO CHECK IF YOU HAVE THE LATEST VERSION FOR YOUR MAKE OF DVD WRITER
    BUT READ THE INSTALATION INSTRUCTION BEFORE APPLY TO YOUR DRIVE
    I SUGEST YOUR PRINT IT OUT AND READ CAREFULLY THEN DOWNLOAD THE UPDATE YOU REQUIRE
    AND THEN FLASH YOUR DRIVE BUT MAKE SURE THIS IS DONE CORRECT AS IF NOT DONE CORRECT CAN DAMAGE YOUR DRIVE IF UNSURE ASK SOMEONE LOCAL WHO YOU KNOW IS A ADVANCE USER
    I DID THIS WITH MY DVD WRITER AND IT SOLVE ALL PROBLEMS WITH MEDIA
    HOPE THIS HELPS
  4. Lost Will Hay's Avatar
    Don't type in CAPITALS on this forum, it won't win you many friends
    (......good advice on the firmware suggestion by the way)
    Will
  5. does flashing ur firmware invalid warranty (uk) its a brand new writer havnt done 1 disk yet
  6. Lost Will Hay's Avatar
    Yes, but I guess only if you make a f*ck of it
    I don't think so, providing you use an official source for it.
    Will
  7. the firmware link is dead any ways im gonna take this writer back to the shop im convinced its faulty
  8. were do i get the tutorial or instructions to get the latest firmware thanxs
  9. sorry mate try this link for firmware updates http://forum.rpc1.org/dl_firmware.php?download_id=309
    this link works ok
    check for your make of drive and dowmload the update
    as before read intruction before apply to your drive
  10. i downloaded the latest firmware from liteon but need the info how to install
  11. It should have come with that info.
    pce's are common, they indicate you are going way too fast, write at 1x & see if that works. also firmware/media updates but come on, its been discussed in the forum alot the answers are the same. Every manf's web site says the same things too.
  12. ok i flashed my firmware thats done the trick no more errors thanxs for the help and advise
  1. VOB Error While Using Power DVD 10
    By skorpinok in forum DVD Ripping
    Last Post: 24th Aug 2010, 14:27
  2. Imgburn - Power Calibration Error message
    By concisa in forum Authoring (DVD)
    Last Post: 12th Nov 2009, 15:39
  3. Power Calibration Area Error
    By zork152 in forum DVD & Blu-ray Writers
    Last Post: 20th Jul 2009, 17:27
  4. I/O Error! Program Memory Area Update Failure
    By Bruxo in forum DVD & Blu-ray Writers
    Last Post: 24th Dec 2007, 07:51
  5. Nero's "Power Calibration Error" fix.
    By AlecWest in forum Newbie / General discussions
    Last Post: 8th May 2007, 19:26
