About 40% of the time when I do a multi-hour capture, Virtualdub stops the capture with the error "audio data lost during capture". I've got the video and audio streams locked. It even does this with low video resolution. I have a 1.8GHz Athlon, and never have significant frame loss or disk IO problems (dedicated capture drive) when I don't get this error. I suspsect some driver issues. Has anyone else had this problem? Any suggestions?
My system:
Athlon 1.8GHz
Windows XP
Hauppauge Win TV card using VFW drivers
Via audio chipset (audio captured through sound card)
thanks,
Kevin
Results 1 to 1 of 1
VDub "incompatible data formats" error
By coyote2 in forum EditingReplies: 10Last Post: 1st Nov 2011, 11:28 -
VirtualDub: "AVI Import Filter error: (Unknown) 80040154"
By Xavier in forum Newbie / General discussionsReplies: 4Last Post: 1st Nov 2010, 00:03 -
DVD Lab Pro Error: "Read data size is over the buffer limit"
By Motinha in forum Newbie / General discussionsReplies: 0Last Post: 29th Oct 2010, 02:49 -
VirtualDub Error 'Says "Couldnt locate decompressor for format xvid"
By shashgo in forum Newbie / General discussionsReplies: 3Last Post: 21st Jul 2010, 23:05 -
"Insufficient audio data or severe sync problem"
By carsskee in forum ffmpegX bugs and suggestionsReplies: 2Last Post: 2nd Aug 2009, 17:31
