VideoHelp.com Forum
  1. I use an eMac with superdrive and usually if backing up a dvd i would use DVDbackup > DVD2One > Toast
    In this case i have recorded a film from tv using my philips dvd recorder which recorded it onto a DVD+RW. Problem is i started it recording like 5 mins before movie started and it has ad breaks in the middle.
    what i want to do is re-author it to start the movie in the right place and cut out all the ad breaks one by one, then burn onto a DVD-R.
    what programs can i use, for the mac, is there any guides on here i can use and how easy is it to do!!
    hope someone can help.
    cheers.
    Ross.
    You might want to pose your question under the "Mac Video Forum" on this site.
  3. ok thanks i will try that
  1. Replies: 0
    Last Post: 12th Dec 2009, 22:13
  2. Cut adverts in .TS-files from Dreambox?
    By nordic45 in forum Editing
    Last Post: 12th Nov 2009, 08:14
  3. With a mac how do I convert a Final Cut Express item to mpeg2 dvd?
    By dagardenguy in forum ffmpegX general discussion
    Last Post: 16th Jan 2009, 12:00
  4. DVD author replacement for mac
    By MarauderFox79 in forum Mac
    Last Post: 16th Nov 2007, 06:01
  5. How do i author dvd menu with chapters + cut commericals...with a WMV??
    By chocolate_brownie in forum Authoring (DVD)
    Last Post: 2nd Jun 2007, 19:00
