When I play my DVDR authored with Impression DVD-Pro on my Toshiba, the search function (fast forward/rewind) freezes up during the search. Anybody know what could be causing this problem? Encoded with TMPGenc, 8000k max using LCPM audio. I authored the same footage using Sonic MyDVD and the search worked fine, is this a problem with the software?
what speed are you burning at? try slowing it down or using a different media
What media are you using?
SLICK RICK
It's happened on both types of media that I use: RITEK DVD+R and FUJI FILM DVD+R both burned at 2x. I'm thinking it's the bitrate but don't see why it's not happening with the Sonic MyDVD software.
This problem seems to come up when you encode your video with TMPGEnc:
http://forum.videohelp.com/viewtopic.php?p=1524983
http://forum.videohelp.com/viewtopic.php?t=281894
AviDemux Fast Forward and Rewind
By MJS in forum EditingReplies: 2Last Post: 2nd Feb 2011, 06:16 -
Sumvision Phoenix will only fast forward or rewind some files.
By muay in forum DVD & Blu-ray PlayersReplies: 5Last Post: 8th Jan 2011, 07:01 -
Joining FLV videos -- playback problems with rewind/fast forward
By gumbygum in forum EditingReplies: 0Last Post: 30th May 2010, 15:32 -
How to Enable a Title for Fast Forward - Rewind?
By Nocturne in forum Authoring (DVD)Replies: 3Last Post: 27th Jun 2008, 23:46 -
Video conversion of .rm to .avi or .mpeg with fast forward and rewind
By skv19 in forum Video ConversionReplies: 3Last Post: 23rd Jul 2007, 21:48
