I downloaded the filter you're supposed to use to remove logos in VirtualDub and extracted it to the Vdub plugins directory. The instructions in the FAQ say to open the video file, which I did, and then add the filter.
How do I add the filter? The help section of Vdub mentions using filters, but it doesn't say what to click or what menu option to choose to add them to your file, and there's no "how to" here about using filters with VirtualDub. There's one for using them with TMPGenc, but not VirtualDub, which is where I need them.
KSJ
video menu... First option.. FILTERS..
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
It must be disabled or grayed out in mine, then, because when I open the video menu (and I can't do it to double check right now, because I'm trying to encode a sample with some new settings to see how it comes out using frameserving) there are no filter options enabled. Trust me, I spent two hours searching all the drop down menus for ANYTHING mentioning filters. I admit, I didn't look at the disabled options. I'll double check when I am able to touch the machine that I'm doing this on again. I don't like to mess with it when it's doing its mojo.
KSJ
Remove Spoilers, Logos etc.
By illogical in forum User guidesReplies: 16Last Post: 14th Jan 2012, 13:13 -
Removing Logos using DeLogo vdub filter
By Matt D in forum EditingReplies: 66Last Post: 19th Oct 2011, 10:57 -
Remove Logos
By Bob740 in forum Newbie / General discussionsReplies: 2Last Post: 9th Dec 2010, 12:19 -
using virtualdub filter to remove text on screen
By snafubaby in forum CapturingReplies: 2Last Post: 11th Jan 2009, 00:09 -
How to remove TV logos on a specified range? (15:22:10 to 15:23:20)
By BlooderButcher in forum EditingReplies: 3Last Post: 27th Jul 2007, 23:01
Statistics
Newest guides
Latest tool updates
New media comments
