Howdy!
Well, I just wondering how to set a "Multiple Audio Streams"?
I have the movie "Electric Dreams" a friend of mine
has recorded from television on a Philips DVD-R
and I also have the original soundtrack on a CD.
- Is it possible to set the soundtrack from the CD
as individuell audio streams?
Is there a limit how many Audio Streams can be set?
The main reason is to do this is that i want to
save both video, soundtrack and MP3-files on the
same DVD. The Mp3-files will I put in a special map
that also contains Winamp for playback on computer.
I have done a DVD included the soundtrack but I created
individual movies for each soundtrack.
- I used Movie Maker to merge a pictures into the movie
and converted it later using TMPGEnc and finnalized all
objects using DVD-Lab. Later I burned on a DVD+RW
and it worked OK, also the the map contains the MP3-files.
thx in advanced,
Besk
Thread: Multiple Audio Streams
You need an authoring tool with multiple audio track support. DVD-lab only supports vobs with multiple tracks,
http://www.dvdrhelp.com/forum/userguides/169251.php
Howdy, Baldrick!
First, thx for your advice and the guide.
Sorry to say it but the guide did not fulfill
my project of filetypes.
Second, good to see that you´re a swedish patriot, he he.
The movie "Electric Dreams" came with the structure:
\VIDEO_TS
VIDEO_TS.BUP
VTS_01_0.BUP
VIDEO_TS.IFO
VTS_01_0.IFO
VIDEO_TS.VOB
VTS_01_0.VOB
VTS_01_1.VOB
VTS_01_2.VOB
1.
a. Imported VTS_01_1.VOB and VTS_01_2.VOB to the project
b. Use it directly without Demultiplexing!!
c. Added the to VOB-files to the connections
d. Draw link from root_meny to VTS_01_1.VOB
e. Draw link from VTS_01_1.VOB to VTS_01_2.VOB
(for playing the next VOB)
f. Imported soundtrack_1 as WAVE-file (48.0 kHZ, PCM, Bitrate 1538 kbps)
g. Added slide 01
h. Set properties for slide 01 (load folder and drop the wave)
?? Did not work
- Will not play the next VOB
- NOSOUND when playing standalone DVD. (Centrum Gemini 330)
+ When palying using PowerDVD worked silcky smooth.
2.
a. Imported VTS_01_1.VOB to the project (test)
b. same as 1b
c. same as 1c
e. Imported soundtrack_1 as WAVE-file (48.0 kHZ, PCM, Bitrate 1538 kbps)
f. Added slide 01
g. Set properties for slide 01 (load folder and drop the wave)
?? Still NOSOUND
3.
a. Also tryed to merge VTS_01_1.VOB VTS_01_2.VOB to the project.
?? Could not figured it out.
Anyone know how to do it?
iTunes and multiple audio streams
By TheNomad in forum Video ConversionReplies: 7Last Post: 28th Sep 2010, 15:18 -
Multiple Audio Streams (Avi)
By nycboriqua in forum EditingReplies: 5Last Post: 26th Sep 2010, 17:42 -
VOB2MPG Multiple Audio Streams
By secretsubscriber in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 4th Jun 2009, 10:04 -
Play multiple streams in DVD (Merge multiple streams)
By sebastien91 in forum SubtitleReplies: 0Last Post: 25th Apr 2009, 18:44 -
By Tobberian in forum AudioReplies: 2Last Post: 14th Jul 2007, 12:54
Statistics
Newest guides
Latest tool updates
New media comments
