I shot a home movie with my digital video cam. I want to crop the video to make it 16:9 to work on my new widescreen tv. I have read several post and found the best way to do this is to crop 60 pixels off the top and 60 off the bottom for a total of 120. My question is can I crop all 120 off the bottom. If I do 60 off the top, I will be loosing alot of my 2 yr old's head ( I didn't do a very good job centering the video). So I want to just crop 120 off the bottom so I loose the less important footage. Is this ok to do or will I run in to a "field A/field B issue or any other kinds of problems??
Depending on what program you are using for editing/cropping, yes, you should be able to do that. TMPGEnc and others allow you to crop right, left, up and down edges. If the video changes to another position, you might have to split it up and crop seperately, then recombine afterwards. I'm afraid I have never tried this, but it should work OK.
How to crop a .MPEG-2 file from the bottom without losing any quality ?
By MGadAllah in forum Newbie / General discussionsReplies: 53Last Post: 26th Jun 2011, 00:44 -
Adding 15 black rows of pixels to the top and bottom of an entire clip
By Terrah in forum EditingReplies: 8Last Post: 20th Apr 2010, 21:48 -
Top 2 pixels and bottom 1 pixel from Sony PD170 are 'blurry'?
By dplus in forum Camcorders (DV/HDV/AVCHD)Replies: 14Last Post: 13th Apr 2010, 10:02 -
Another question: Converting square pixels into round pixels.
By Earthling2000 in forum Newbie / General discussionsReplies: 13Last Post: 23rd Nov 2009, 10:20 -
KMPlayer - VMR9 - video tearing about 20 pixels from bottom!
By totalz in forum Software PlayingReplies: 0Last Post: 29th Oct 2009, 09:53
Statistics
Newest guides
Latest tool updates
New media comments
