I'm evaluating VCD Easy (1.1.7.2 Trial) to create my photo album on (S)VCD.
I'm intersting more on quality than on special effects (transition, sound background).
For this reason I have compared some sample made using MPEG-1 (VCD 2.0) and MPEG-2 (SVCD) both on PAL standard.
Although my camera+DVD player+TV should be a good system (SONY 5.1 MPixels with Zeiss Lens, Loewe Xemix DVD and Loewe 32" 100Hz TV), I get these strange results:
MPEG-1: quite good definition but a lot of flickering although 0.6 filter rate (with higher rates the image has a 'blur' aspect)
MPEG-2: worse quality (pixels seems bigger, sloping edges between bright and dark zones appear jagged or 'saw-edgeg') but no flickering
P.S. I used always spline resize filter as suggest on article I have read
Yet some other question:
-does anybody suggest me a simple, free, file/directory browser (similar to Win Explorer) than gives the thumbnail for images files (like Explorer does on 2k or XP, unfortunally I'm using Win98)
-is it possible to set the default wait time to -1 (infinite) as default
Thread: MPEG-1 vs MPEG-2 quality
The spec for Mpeg1 (VCD) still and Mpeg2 (SVCD) still is almost identical. It could be some sort of compatibility issue. Try your disks out on some other equipment, especially with a standard definition TV.
high quality mpeg-2 encoding
By deadrats in forum Video ConversionReplies: 201Last Post: 6th Oct 2010, 11:26 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video StreamingReplies: 0Last Post: 27th Nov 2009, 04:40 -
Which format produces better quality overall MPEG-2, MPEG-4 or .x264?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 8Last Post: 31st Aug 2009, 03:00 -
avi to MPEG quality loss?
By prcole18 in forum Video ConversionReplies: 1Last Post: 7th Oct 2008, 10:38 -
how to convert these files to best quality mpeg?
By curt1sw in forum Newbie / General discussionsReplies: 11Last Post: 19th Oct 2007, 16:43
Statistics
Newest guides
Latest tool updates
New media comments
