Ive got a Panasoniv nv-ds30 cam. Its maby 2 years old and i have used it like 5-6 tapes and a lot of capturing to my PC.
I have always used Sony Excellence miniDV tapes. But later ive started to use Fuji tapes.
Now to the problem.
When i playback the video in the cam i hear no sound and the image is strange with a lot of flicker and gren dots in it.
When i capture to my PC its the same problem only now with sound. But the sound is also very pour with a lot of noise and .
Do you think a cleaning tape will fix this, ore is it something els?
Thread: Problems with Panasonic cam
I would send it to a reputable technician with a description of the problem. It does sound like a dirty video head, and if it is, it should be relatively inexpensive for him to clean for you. I do not advise cleaning it yourself, the idea of those abrasive cleaning tapes really rub me the wrong way.
Hello.
But i doubt it would get any worse by try to clean it with a cleaningtape?
As I said, I do not like to use them, if used incorrectly, you could damage your camera. But one time should not do any harm.
Hello.
Anyone had any problems that a cleaningtape solved, in case what kind of problem?
Hi,
Sorry to bring this thread back up again, but my Pana DS30 has started to exhibit the same problems all of a sudden (just under 2yrs old).
Did you get you machine fixed, or does anyone else know why the picture and sound are breaking up?
I'm guessing it's something to do with the real-time encoding as the picture is very 'laggy' when viewing on the PC via Firewire......
Thanks in advance for any suggestions,
Regards
Casp
p.s. I have tried a cleaning tape, but it made no difference and my local service centre want a £36 deposit to even look at it.
Time for an HD cam.. Last cam was Pana. DVC80.. Next will be?
By sdsumike619 in forum Camcorders (DV/HDV/AVCHD)Replies: 17Last Post: 25th Nov 2011, 18:35 -
Panasonic Dv cam - Onlocation - Premiere pro cs5.5
By jj3502 in forum Camcorders (DV/HDV/AVCHD)Replies: 1Last Post: 26th Jul 2011, 04:51 -
How Create ACHD side by side compatible with Panasonic 3D Cam and HDTV?
By castana in forum Video ConversionReplies: 7Last Post: 25th Jul 2011, 15:47 -
3D Panasonic HD cam to be released
By aedipuss in forum Latest Video NewsReplies: 7Last Post: 31st Jan 2010, 21:26 -
Pinnacle 9 - JVC cam problems
By Maarten in forum CapturingReplies: 3Last Post: 19th Jan 2009, 16:38
