  1. Looks like I can't use the Peach smoother I was using with Avisynth 2.08 so I'm hoping someone can recommend a good and fast smoother and maybe a sample script for what settings to use for regular VHS type captures. My vhs tape caps are pretty clean. Thanks all.
  2. Get Slack disturbed1's Avatar
    http://www.avisynth.org/warpenterprises/
    Pick and choose.
    Peach Smoother is available for 2.5
  3. I tried it. Doesn't work for some reason. Which one you use?
  4. Get Slack disturbed1's Avatar
    Vaguedenoiser, Msmooth, Msharpen.
    What's the error reported by Avisynth? If you're using CCE, some filters won't produce the same results on each pass, and cause a CRC check error with CCE. If that happens you'll need to find a CRC patch for CCE, I think there's one floating around.
  1. Best smoother filter in VirtualDub?
    By dimtim in forum Newbie / General discussions
    Last Post: 11th Mar 2007, 00:00
  2. Replies: 0
    Last Post: 7th Feb 2006, 13:14
  3. dvd2svcd 1.2.2 and temporal smoother
    By sark000 in forum Authoring (VCD/SVCD)
    Last Post: 13th May 2004, 12:12
  4. Best Soften/Smoother Filters
    By oscdude in forum Newbie / General discussions
    Last Post: 15th Apr 2004, 16:22
  5. Smart Smoother Filter
    By Alienz in forum Video Conversion
    Last Post: 19th Dec 2001, 23:01
Slysofts AnyDVD HD removes DVD and Blu-ray encryption and region coding. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
