Hallo,
maybe You know any libraries ( or maybe ready to use program ) that would be
able to deal/join with MPEG2 files ?
Those MPEG2 files are of the same type ( parts of the same large MPEG2 file )
thanks in advance
pik
mpgtx will do this
Hallo
From the user intrface point of view it is exactly what I was looking,
but there is one problem, that I discovered during testing.
Meida player and Zoom player at least show artifacts at the splice point of joined mpeg files. Although I found some note at mpgtx home page:
"MPEG files joined with mpgtx can show artifacts at the splice point. This is not a bug from the editor but rather from the player. Technically mpgtx sets the Broken Link flag in the GOP header which tells the player to discard leading interpolated (B) frames. Some players will ignore this flag, thus displaying artifacts. mtv and mtvp are known to handle these files correctly. You can find these tools at http://www.mpegtv.com/. "
but I still wonder why for example TMPGencPlus joined file that do not show such artifacts ?
Maybe there is also other batch tool that can join files that won't show such artifacts ?
grretings Maciek
Perhaps Tmpgenc is smarter and replaced the interpolated frames (that were rubbish anyway) with repeat frames of the last known good frame before these.Originally Posted by pikpus
The human eye may not be able to see those frames (they were two normally as the normal sequence usually used is IPBBPBB...) but can easily identify the green blocks appearing for just a couple of frames.The more I learn, the more I come to realize how little it is I know.
Stream MPEG2 file in JAVA
By PCNG in forum ProgrammingReplies: 1Last Post: 6th Oct 2011, 04:16 -
Free program to join vob files with dts audio
By shans in forum Newbie / General discussionsReplies: 2Last Post: 1st Oct 2011, 06:51 -
A simple program that will join groups of 4 or so video files?
By Toki_Wartooth in forum EditingReplies: 9Last Post: 3rd Jun 2010, 18:21 -
Good program from cut/join .mpg .wmv files.
By Beautiful Alone in forum EditingReplies: 1Last Post: 27th Jul 2009, 16:57 -
how to join(splice) mpeg2 files without decode them and without artifacts?
By mb508 in forum ProgrammingReplies: 1Last Post: 7th Aug 2007, 06:49
Statistics
Newest guides
Latest tool updates
New media comments
