VideoHelp.com Forum
    Using my Sansui VRDVD4005 DVD-RW Recorder & VCR, I dub my home movies on VHS to DVD-RW in VR mode and then edit them.
    Does anyone know of a stand alone DVD player that will play back these DVD-RS's after they're finalized, so that I can then input the signal back into the Recorder and record a DVD-R that will play in "most" DVD players???? Thanks in advance. Mike
  2. hi MichiganMike, ..welcome to the forums :P
    I may be wrong, but I recall reading a similar post about someone wanting
    to transfer their DVD+R's to DVD-R's.. and the response back went some
    thing like this:
    DVD Decrypter - ISO Read - - from your -RW disk
    DVD Decrypter - ISO Write - - to your -R disk
    Good luck,
    -vhelp
  3. Originally Posted by MichiganMike
    That sounds like an bad idea.... you will add too many extra conversions/loss into process. Convert mpeg2 in DVD Player into analog video, running it through cables (f.e. S-Video) and then converting analog back to mpeg2 in DVD Recorder. You should look into option of doing (creating) DVD-R on PC. Either just plain copy or make it more compatible, re-author it again. Result ? No additional loss at all.
  1. stand alone dvd player and mpeg2 files
    By sportflyer in forum Newbie / General discussions
    Last Post: 17th Feb 2010, 07:34
  2. First Stand Alone RM/RMVB DVD Player
    By sushix in forum DVD & Blu-ray Players
    Last Post: 7th Jun 2009, 01:42
  3. Stand-Alone DVD Player recommendation
    By -mm- in forum DVD & Blu-ray Players
    Last Post: 2nd May 2008, 12:13
  4. Adding subtitle to a movie and use it only in a STAND-ALONE DVD player ?
    By bradford in forum Newbie / General discussions
    Last Post: 27th Oct 2007, 01:59
  5. Stand alone player won't play DVD-R
    By NHLroyrocks in forum Newbie / General discussions
    Last Post: 27th May 2007, 16:53
