VideoHelp.com Forum
Results 1 to 13 of 13
  1. Can anyone tell me how I can burn a MPEG2 to DVD using Nero 5.5.5.1? I cannon choose the DVD Video possibility. Nothing there is written about this on the Ahead site.
    Please help!
  2. you need to explain better..are you trying burn DVD FORMAT information to DVD MEDIA??..or VCD/SVCD FORMAT to DVD MEDIA??
  3. Sorry, I should have explained better in the first place. What I'm trying to do is burn several MPEG1 and 2 films to 1 DVD using Pioneer DVR-A03 and Nero Burning Rom. Nero however does not allow me to access the Video DVD Format. So, I want to burn (S)VCD files to DVD. You think it's possible?
  4. Last I heard no...DVD Media has to be AUTHORED (burned) in DVD format not SVCD...what you would to do is extract the mpegs out of the (S)VCD and re-author.
    I have a slightly different question -- How can you burn a DVD image to CD-RW (on that would fit onto CD) using Nero 5.5.5.1? I can't seem to work it out, and my forum searches have proven fruitless. I've run out of search terms to try.
    Open Nero, choose video-cd, deselect 'create standard compliant cd', select new, click and drag your file- that's it!
    I performed a dvd rip, encoded it to DVD(NTSC)with a 2-pass VBR in TMPGEnc and burned the cd in Nero this afternoon.
    Incidently, I did locate the necessary problem-solving information from this site...
  7. But surely all you've achieved is to burn a non-compliant VCD?
    I have made a miniDVD (CD containg DVD material - only playable on PCs with MPEG2 player or very limited number of DVD players)
    I authored it to Hard Drive using SpruceUp and then burnt as ISO to CD-RW and played on PowerDVD 3.0
    <font size=-1>[ This Message was edited by: ember on 2001-10-23 21:39:03 ]</font>
    No, with Windows Media Player and Elecard Mpeg-2 player I can view this on my pc...and with a software dvd player installed on other's computers, I feel confident that WMP, upon locating the proper codec, will play it too.
    Admittedly, the cd only holds 15-18 minutes, but it appears ideal for short projects preserved at a high resolution...
  9. But the option you chose on NERO was VCD (albeit non standard) - so it cant be miniDVD!!!
    miniDVD is basicly a DVD but on a CD-R(W) instead of a DVD disc. miniDVD is also sometimes called cDVD. A miniDVD does only fits about 15 minutes video on a 650 MB CD-R(W).
    (definition from this here site!)
  11. I know that - but - you are basically making a non-standard VCD: You are dragging your MPEG2 DVD file into NERO, then you are encoding it to MPEG1 at 720 res. Look at the file structure in the window pane above- it is VCD format.
    You have simply encoded your DVD clip to MPEG1 using NEROs encoder, then created a non-standard VCD.
    okay -- i revived this thread to get an applicable answer to *my* question -- so again, i ask, how can i burn a nero dvd image to a cd-rw, one thats small enough to fit onto a cd? -- if nero hasnt added the possibility of burning miniDVD/cDVD, i'd be really disappointed in them, they being so forward-thinking on non-compliant everything else
  13. I would use the CD-ROM UDF template and drag the AUDIO_TS and VIDEO_TS folders (made with the program used to author your DVD files) into the pane and then write.
  1. Convert MKV to DVD video for burning with Nero Vision
    By OreRockOn in forum Video Conversion
    Last Post: 4th Jan 2010, 10:42
  2. Problem burning data DVD using Nero 6 burning rom
    By thebluekey_17 in forum Newbie / General discussions
    Last Post: 19th Feb 2009, 13:14
  3. Nero Burning Rom 8.3.6.0
    By jebinio in forum Computer
    Last Post: 14th Sep 2008, 10:29
  4. how to create folders in nero burning rom or express?
    By jyeh74 in forum Newbie / General discussions
    Last Post: 22nd Dec 2007, 23:54
  5. DVD-ROM to DVD Burner Direct Burning
    By Wilson7777 in forum DVD Ripping
    Last Post: 15th Jun 2007, 11:37
