VideoHelp.com Forum
Thread: MPG problem
    I have an .mpg that could hear the sound, but can't see the images........
    I try using the converter to convert it to other format, but the message appear "this formate is not supported".
    How do I see the image along with the sound? Is there anything I can do?
    What player only showed black? Do you have Mpeg-2 codec installed? What converter are you referring to?
    Hello.
    thanks alot............so it's the MPG-2 codec........okay!
    Another problem.......When I burn the SVCD, the screen is shakie....why is that? I use Nero 6.0. I burn it in NTSC mode cause my dvd played in NTSC mode only. Plus the .mpg is ntsc mode too.
    The field order may be wrong, or the media may be bad.
    Hello.
    If i view in the pc, it's prefectly in position, but when I burn to cd, it's shaky.
    So you may want to try a different brand, but in the meantime, try burning at a slower speed, if possible.
    Hello.
    I burned the lowest speed and it still shaky.....
  1. mpg to avi(xvid) problem
    By okman in forum Video Conversion
    Last Post: 6th Jun 2009, 05:00
  2. problem with mpg format
    By volam in forum Editing
    Last Post: 17th May 2009, 13:31
  3. I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
    By emanmb in forum ffmpegX general discussion
    Last Post: 18th Apr 2008, 14:48
  4. mpg to DVD problem
    By toughdiamond in forum Newbie / General discussions
    Last Post: 21st Nov 2007, 06:17
  5. Problem with .VOB to .MPG
    By SilverFalcon in forum Video Conversion
    Last Post: 30th Jul 2007, 13:27
