I would like to make slide shows with selectable subtitles.
The subtitles should be generated from the "Image Description" or "User Comment" as contained in the EXIF (Exchangeable Image File ) tag in the .jpg file. I found an option in Ulead DVD Picture Show to add a description by hand. These titles however get merged into the .mpg file, instead of true selectable subtitles..
I found exiftags (Linux) that extracts the "Image Description" from a .jpg file. I could write some scripts to generate a text file. From what I read from other postings, the usual path appears to be:
1. convert .txt to .srt using Subtitle Studio
2. convert .srt to .sup using srt2sup
3. import the .sup in IfoEdit.
The other path that I see, is to use ACDSee in slideshow mode and record the svideo output on a Camcorder. That would be straightforward, but sacrifice qualify.
Is it me, or is there a simpler way of accomplishing this?
thanks for your time
Results 1 to 1 of 1
High definition slide shows on DVD.
By EagleW in forum Newbie / General discussionsReplies: 13Last Post: 9th Jun 2010, 15:17 -
AVI to DVD with selectable subtitles
By egooxenos in forum ffmpegX general discussionReplies: 9Last Post: 5th Dec 2009, 02:04 -
DVD slideshow GUI - problem with subtitles imported from exif
By jaceko in forum ProgrammingReplies: 10Last Post: 19th Jul 2009, 22:00 -
Best programs for .jpeg slide shows?
By Captain Satellite in forum Newbie / General discussionsReplies: 17Last Post: 30th Oct 2007, 09:50 -
DVD selectable subtitles
By exekutive in forum ffmpegX general discussionReplies: 6Last Post: 24th Sep 2007, 12:36
