VideoHelp.com Forum
  1. I have some home videos I made and I want to share them with friends, etc.
    One file is maybe 10 min, but when I export using imovie, and avi settings of "better" for example, the resulting file is close to 1gb. The compression in imovie offers dv, dvntsc, etc., I don't see options for sorenson, cinepak, etc.
    How do I export to a reasonable sized file? Do I need to take that file and then convert using ffmpeg, or something like that?
    what .avi codec are you using... this has everything to do with it. You should install DivX Pro.
    AV Industries - Divx®-Enabled DVD Players
  3. No Longer Mod tgpo's Avatar
    To export to other Quicktiem Codecs simply do the following:
    Click File/Export
    Set it to the following:
    Export: Quicktime
    Formats: Expert Settings
    Set export to Quicktime Movie
    Click Options
    Under Video click Settings
    You can then select the Quicktime Codec you want to use.
  4. I see where I can do that, the only issue is, I can't export to .mov, as i need to share this with the PC world. that's why I was looking at avi as an option.
    thanks for the help
  5. No Longer Mod tgpo's Avatar
    PCs have no problems playing Quicktime files.
  6. I didn't think WMP could play .mov files. THis would assume that the PC'er has QT installed, right?
  1. quicktime pro will exporting to h.264 solve this huge file size issue?
    By cybershot in forum Newbie / General discussions
    Last Post: 10th Oct 2010, 21:43
  2. Exporting VHS burn from IMOVIE HELP!
    By durdenwasright in forum Mac
    Last Post: 23rd Oct 2009, 08:35
  3. Reducing Filesize of .avi
    By jonesb in forum Newbie / General discussions
    Last Post: 4th May 2009, 11:01
  4. exporting imovie video for web streaming
    By beforethedawn in forum Mac
    Last Post: 23rd Oct 2007, 09:56
  5. Replies: 3
    Last Post: 29th Jun 2007, 18:52
