i bought a liteon 411s. please tell me what all i need. i wanna burn movies.
so far ive downloaded dvddecryptor, dvd shrink and dvdfab off of advice
Results 1 to 10 of 10
Thread: im a total noob, need help
*sigh*
Yes you are a total NOOB, what movies are you wanting to burn what format are they in, are they dvd to dvd or avi to dvd or are you wanting to make vcds.
God knows NOB sorry NOOB
You need to study the DVD Rip and Author sections for the program guides you want to use. Yes, that's what you need.Originally Posted by incubus2012Hello.
Before you get crucified for not reading, or even looking at the page, look to your left under "How To" and "Guides" not hard at all.
Blah, blah, blah
lol what he saidOriginally Posted by nufan292
dvd to dvd
Then you are in luck. Plenty of guides and reviews of tools are there for your reading pleasure.Originally Posted by incubus2012
I spent 6 months reading before I bought, downloaded, or installed anything. I suggest you take some time on your own before asking for any help for now.
Jeff
Yep, reading the guides on yr left will do the trick!!
DVDShrink is an excellent choice for a newbie... Just read some guides on it!! There are plenty around...
Good Luck!
LeoNapierThe Truth Is Out There - X Files
What Hiptune said. I also spent six months just reading up on everything. You can probably cut that down since you already got the burner. Just using this (and doom9's) website, I was ripping, encoding, authoring and burning right out of the box with my 106. It's more complicated than I thought it would be, and it is a bit intimidating when you first start, but give it awhile and just pick one thing at a time to learn.Originally Posted by hiptune
I recommend backing up. Figure out DVD Decrypter (it's easy) and you're on your way.
Possible to encode a Premiere Pro video in DivX format? (total noob seeks advice)
By metathran in forum EditingReplies: 24Last Post: 30th Jan 2010, 20:55 -
Total video noob, need to edit & convert videos
By HDn00b in forum Newbie / General discussionsReplies: 3Last Post: 6th Nov 2009, 00:58 -
Total noob needs help encoding from Xbox 360 footage
By FreeBaGeL in forum Newbie / General discussionsReplies: 0Last Post: 17th Feb 2008, 14:27 -
Total Noob Question - NTSC / PAL
By fredfillis in forum DVB / HDTVReplies: 15Last Post: 10th Jan 2008, 05:16 -
TOTAL NOOB... how do u use WinAVI the correct way?
By bl@h in forum Authoring (DVD)Replies: 3Last Post: 19th Jun 2007, 14:57
