Well I have a relatively short film on VHS that I am going to capture then convert. My question is this, the film is just under an hour long and I would like to convert it to VCD or SVCD, I have used a bitrate calc and I am going to have it at about 1500kbit/s should I convert to XVCD or SVCD? My standalone plays them both fine so im essentially asking witch will give better quality, im leaning towards SVCD at the moment but would like some imput, thanks.
With a 1500 bitrate I would go with XVCD. Theres a good chance that 1500kbps will give you macro blocks at SVCD resolution.
Considering that your source is VHS anyway, you are probably better off creating a XVCD by capturing MPEG-1 352x240 @ 1500kb/s. I've made SVCDs at 480x480 and at a higher bitrate and find the quality is the same using VHS as the source.
/MW"There's a fine line between 'genius' and 'insanity'."
Little Problem during encode in Format Factory
By Stef2010 in forum Video ConversionReplies: 1Last Post: 23rd Aug 2010, 10:43 -
Encode HD video to what format?
By dphirschler in forum Video ConversionReplies: 1Last Post: 13th Oct 2009, 05:04 -
Cannot encode VOB to ffmpeg format ***UPDATED***
By pjfl29 in forum ffmpegX bugs and suggestionsReplies: 4Last Post: 31st Jan 2009, 22:50 -
Better format to encode to: MPEG2 or DivX/AVI?
By Grunberg in forum Video ConversionReplies: 15Last Post: 15th Feb 2008, 08:29 -
Cannot encode VOB file to any format - all binaries installed
By designillinois in forum ffmpegX bugs and suggestionsReplies: 4Last Post: 26th Aug 2007, 13:05
Statistics
Newest guides
Latest tool updates
New media comments
