VideoHelp.com Forum
    Greetings:
    Using Maestro to compile a DVD I'm getting an invalid frame rate error. I found it only happens if I have the menu in place. Them menu is a simple still image 4 button menu created with DVD Menu Studio. If I remove the menu, all compiles fine. Add it back, no luck.
    PC with Intel MB:P4-3.0 800FSB, (2)200GB HDs.
    Thanks very much for any sugestions and help.
    Cheers,
    I realise this is a year on from the original question, but if anyone is interested I have found the solution!
    The critical thing is this:
    The P4 is treated by the PC as a dual processor, and it seems Maestro doesn't like this. I've just spent days re-creating menus using different software, only to find the problem persists. The way round it is this:-
    With Maestro running, control+alt+delete to bring up the Task Manager.
    Click the Processes tab.
    Right-click dvdmaestro.exe in the "image name" column.
    Click on "Set Affinity"
    Un-check the CPU1 box.
    Hey presto - Maestro will now function correctly!
    Hey:
    I'm still subscribed, so thanks for the belated help. I found that the dual cpu was the problem. I found a program that works to set it to one. Don't remember where I found it, google for it. I used ti in a batch file that I call instead of the executable to start maestro:
    cd [my maestreo exe directoyr]
    start maestro.exe
    process -a maestro.exe 01
    exit
    That has been working for me and is more automated.
    Thanks again,
    Oops, edited, replied to wrong thread, sorry...
  1. My DVD backups are "invalid" in Sony Blu ray player
    By KeithMckane in forum Authoring (DVD)
    Last Post: 26th Feb 2010, 15:11
  2. Replies: 1
    Last Post: 6th Dec 2009, 15:19
  3. HCenc "Invalid MPEG-2 Frame rate" error.
    By Maikeru-sama in forum Video Conversion
    Last Post: 8th Jul 2008, 18:09
  4. Philips DPV-5992 not recognizing a USB HD - "Input Invalid"
    By benvid in forum Newbie / General discussions
    Last Post: 21st Jun 2008, 17:02
  5. "Invalid DVD navigantion Structure" Help
    By X_Splinter in forum Subtitle
    Last Post: 19th May 2008, 14:44
