VideoHelp.com Forum
  1. hi, jus a quick question, again i dont know if there is any truth to this but i heard that recording at ur burners top speed, whether cd or dvd rewriter can damage the laser and reduce the life of the dvd writer?
    is this bullsh.t or should i start burning at 2x instead of 4x??
    thanks
    It's BS. Using a 4x burner at 4x on 4x certified media is fine. Burning 1x media at 2x generally requires a hotter laser and could cause problems.
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
  3. Member garryheather's Avatar
    It's more "misinformed" BS.
    If you look at the link I posted earlier, you will see that some Pioneer drives could be damaged out of the box by writing to certain discs before a certain revision of firmware.
    So whoever told you that had his / her info deeply rooted in fact in part, but was inaccurate.
  1. High Speed Component Cables?
    By dpunkz in forum Newbie / General discussions
    Last Post: 21st Jun 2011, 22:27
  2. JVC SR-DVM70US High Speed Dubbing
    By sd1233 in forum DVD Ripping
    Last Post: 29th Jul 2010, 14:58
  3. Options for continuous high-speed recording?
    By dbooksta in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 9th Apr 2010, 11:36
  4. High speed hdmi? Is this a marketing gimmick?
    By yoda313 in forum DVB / HDTV
    Last Post: 1st Aug 2009, 21:01
  5. High-speed internet through wireless network? Help!
    By Super Warrior in forum Computer
    Last Post: 18th May 2007, 11:34
