VideoHelp.com Forum
Results 1 to 11 of 11
  1. I have some episodes of Naruto in AVI(divx) format and wish to convert it to a format which allows me to play on my DVD player.
    Can someone tell me which format is the best to use, i want quality and be able to fit quite a few episodes on one DVD disc.
    Thanks, for anyone who can help me.
    Is Oxymoronic. You get one or the other.
    What are the details on the source files? Garbage in = Garbage out
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
  3. OK. Let me put it a different way.
    Answer this question if u convert divx(animations) to VCD or DVD.
    Pls give me an opinion to which is better(or you prefer) conveting to VCD on a DVD-R or converting to DVD(mpeg2) on DVD-R.
  4. some help pls
  5. Member teegee420's Avatar
    Let's assume first that your source files are of decent quality, in which case you will want to convert to DVD mpegs. If you use a target bitrate of 4000kb you can fit about seven 22 minute episodes on a 4.7 GB DVD. If you want quality, you're not going to squeaze much more eps than that on a DVD. However, if your AVI's are "just ok" quality, you might want to consider VCD, which can fit about three 22(or so) minute eps on one 80 minute CD-R.
  6. Thanks for the info Teegee420, just what i need to get me started. There should be more helpful people like u, unlike some idiots.
  7. I would suggest you convert the episodes to SVCD. This way I burned 9 episodes of Fullmetal Alchemist on one disc. I think it is much better than VCD because you can read the subtitles better.
  8. Member bugster's Avatar
    I would be careful who you are calling an Idiot, what Gazorgan said was absolutley correct, Garbage in = Garbage out. If your source is excellent quality (and that is subjective anyway), then DVD with full D1 (720 * 480 res, high bitrate) is the way to go. Then we go to DVD with 1/2 D1 res (352 * 480, lower bitrate) and then you can go SVCD or VCD.
    Higher bitrate = higher quality = lower playing time.
    As an example, a 2hour divx movie that is 1.4Gb is probably worth a full 4.7G DVD with an average bitrate of 4500Kbits. If your two hour divx movie is only 700Mb, I would encode it at 1/2 D1 resolution with an average bitrate of around 3Kbits, leaving room for another hours worth of equivalent quality material on the disk if I so wished. (these are my personal guidelines and not hard and fast rules)
    I know you are talking episodes, not movies, but the same principal apllies as it is overall playing time that matters. If you have a DVD burner, I wouldn't bother with VCD or SVCD on CD media. VCD video is OK for DVD, but SVCD is not compliant. In all cases your audio should be at 48Khz sample rate.
    Hope this helps.
  9. @bugster:
    Why do you say thar SVCD is not compliant? That depends on your DVD Player. I have no problems with SVCDs on DVD.
  10. Member bugster's Avatar
    Originally Posted by Kane
    @bugster:
    Just because your DVD player will happily play SVCD on DVD does not make it part of the DVD-Video standard. See here .
    Your current player is happy with them, but what happens when you replace it, there will be no guarantees these same DVD's will play correctly or at all.
    FYI, my DVD player is happy with them too, but I only use SVCD on DVD-Video if the source material is in SVCD spec to start with. I will never encode it that way myself.
  11. Member ZippyP.'s Avatar
    And the difference between SVCD and 1/2 D1 isn't that great anyway.
  1. naruto sub (eng)
    By AllStarMomo in forum Subtitle
    Last Post: 10th Nov 2009, 13:54
  2. VCD to DVD
    By Argon in forum Mac
    Last Post: 5th Oct 2008, 10:01
  3. Will a DVD player play any files but DVD/VCD and CD audio?
    By brassplyer in forum DVD & Blu-ray Players
    Last Post: 24th Sep 2008, 19:32
  4. Replies: 2
    Last Post: 19th Oct 2007, 06:54
  5. Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
    By scratchman in forum User guides
    Last Post: 4th Jun 2007, 01:36
