VideoHelp.com Forum
  1. Member Zetti's Avatar
    Hi all,
    Please, forgive me if this has been posted before, I've made a search using the words "TMPGENC" and "Demux", took a quick look but hasn't found anything related to that;
    Still, it's very unlikely I am the first one with this problem, as it happened to a largely popular software;
    I extracted a MPEG file from an DVD-R disc (using TMPGENc DVD Author) and saved it properly at the HDD - OK this part, 2.0 AC3 audio muxed in;
    Then, I went to do the demuxing at TMPGEnc , the file is 38 min long.
    While audio has been demuxed properly, video M2V file showed only 19:15 minutes....I tried 4 times and in all cases TMPGENc demuxed only the same part always of the MPEG file
    No error messages......curiously, as I said, AC3 demuxed file is OK;
    It happens ONLY to this specific file...any guess ? I've tried 4 times
    Completely weird for me
    Thanks,
    Zetti
    Try demuxing with another program, like DVD2AVI. What program r u using to test/play the demuxed *.m2v file with?? Normally, MPEG-2 video of that we put on DVDs is VBR. Some player programs (WMP?) do not accurately report playing times with VBR streams; try playing your file (and slogging through all 38mins of it) and see if it indeed is as long as expected. The demuxed *.ac3, though, is CBR, so playing time indication is accurate. If the playing time is really wrong then that file may be corrupted (at least the video part).
    M: Bond, I want you back.
    James Bond: I never left.
  3. Member Zetti's Avatar
    Thanks, actually all softwares indicated the too short length, VS7, DVDitPE and WMP;
    WOMBLE MPEG demuxed it properly, so I really believe there's a buggy in TMPGENc;
    Zetti
  1. I have a .mpg file that I need to demux I want the audio..
    By J Tinsby in forum Video Conversion
    Last Post: 23rd Jun 2011, 18:20
  2. mpg won't stream until the entire thing is downloaded.
    By flycast in forum Video Streaming
    Last Post: 19th Dec 2009, 22:23
  3. Replies: 1
    Last Post: 19th Sep 2009, 14:41
  4. Why does this mpg file doesn't play sound in my divx player?
    By Stealth3si in forum Newbie / General discussions
    Last Post: 5th Jul 2009, 19:00
  5. MKVExtractGUI does not demux entire mkv?
    By avkhatri in forum Video Conversion
    Last Post: 7th Feb 2009, 19:03
