VideoHelp.com Forum
  1. I have extracted the audio from a dvd to a wav file using smart ripper and AC3 Tools and I would like to know if it is possible to extract the music tracks from the dvd direct or from the wav file I created.
    regards
    Lynette
  2. Member MOVIEGEEK's Avatar
    You can extract chapters from a DVD by using DVDDecrypter->IFO mode->Stream Processing->Demux or by using DVDShrink->Start/End,SmartRipper should have the same function.
    You can split your WAV into tracks by using www.cdwave.com
  3. Member hech54's Avatar
    If you already have one-big-long .wav file and want to break it up....CDWave is awesome at it.
    "CD Wave is a program designed to aid in CD-Recordable mastering. It was built for splitting WAV files from any source, like LP, tape or even CD. After recording, you can let CD Wave automatically calculate split points, or you can manually add and delete split points. After this, you can write out the tracks as individual wave files and use any CDR mastering program to write a disc that has no clicks or pops in between tracks. Also supports 24-bit and surround audio.
    CD Wave can also act as a simple audio recorder and editor, allowing you to record and playback audio, and cut out parts that you want to keep."
    http://www.homepages.hetnet.nl/mr_3/.../milosoftware/
  4. Thank you both for the replys. CD Wave is certainly very handy.
    regards
    Lynette
    Hi all,
    I am new too, so can you show me step by step after I use DVDDecrypter then how I convert it to wave so I listen music from CD (that mean I have to wrtie it to blank CD)
    See the Guides on the left.
  7. Banned
    I'm using #1 DVD Audio Ripper,it's pretty good,it can rip to mp3,wav,ogg,wma,support to edit start time and end time.
    http://www.apollo-tech.com/dvd_audio_ripper.exe
  1. extract music from bin image?
    By pensioner in forum Newbie / General discussions
    Last Post: 18th Apr 2011, 23:01
  2. How to extract music only?
    By UncleBose in forum Audio
    Last Post: 14th Nov 2009, 08:51
  3. Replies: 0
    Last Post: 13th Oct 2007, 18:15
  4. Extract special CD-music to harddrive
    By Blå_Mocka in forum Audio
    Last Post: 21st Jul 2007, 06:51
  5. Can I burn a music video along with music trax onto the same disc?
    By Kalla B in forum Newbie / General discussions
    Last Post: 4th Jul 2007, 12:02
