Panasonic DMR-E80H is any one have any problem's getting DVD-R to play on other DVD player's that should play. I have read that some Panasonic recorder's do not have a good authoring process. Just like on the PC with old Nero software same media but when nero fix the burning problem after 5510 the burned DVD start to work on more DVD player's.
I was reading this link
http://www.dvdrhelp.com/forum/viewtopic.php?t=178094
S-Man,
I believe there is an option in the DMR-E80HS to select "DVD-R Compatibility". I don't know for sure as I have the DMR-HS2.
Try turning that feature on and see if it helps. If it doesn't, then its due to the way DVD-R's are authored with a Panasonic, they seem to have compatibility issues when they are played with other DVD players. Its pretty much seems hit or miss. Also, even if it does play, it may not play correctly (ie, lose the functions of FF and RW, this happened to me on a APEX 5131).
See here...
http://www.dvdrhelp.com/forum/viewto...093&highlight=
and here...
http://www.dvdrhelp.com/forum/viewtopic.php?t=175473
Good Luck,
Tearren
The "DVD-R Compatibility" option really just affects the ability to use the "high speed" (lossless) dubbing from the hard drive to a DVD-R disc. Mainly, I think this just turns off "variable bit-rate" recording, and forces constant bit-rate recording.Originally Posted by Tearren
My impression is that it's really a relative handful of DVD players that won't handle a DVD-R from a Panasonic machine -- some older machines, some Apex machines are the ones I've heard. I've got an Apex AD-5131 that won't load up one of my Panasonic DVD-R's at all.
For whatever that may be worth -- I hope it helps!
thoots
And Daewoo...
Pinnacle Studio 8 and DV home video editing (ver.9 already home)
donpedro,
Oh, yeah, forgot about Daewoo. It kinda goes like "geez, guys, pay more than twenty bucks for a DVD player, and see if you get better results!"
I say that in jest, though -- dang, I love how the AD-5131 (and other Apexes) work with VCD discs, which I use to view my digital pictures on the TV. When a bunch of those came back for sale at Wal-Mart a while back, I bought three of the suckers...
thoots
Well... my Deawoo was not that cheapOriginally Posted by thoots
It was $98 about a year or so ago...... All this reminds me time that I was starting with DVD Burners (PC). There were these components that you could blame for not playing in DVD Player and you could spend weeks to figure out which one is your issue. Media quality (cheap or expensive), format +/-, way how DVD is authored, way (options) how it is burned (UDF...), which version of burning soft are you using (famouse Nero issue), burning speed (even when it will let you burn 2x it doesn't mean you can), burner brand/type/firmware combination (old Sony DRU-500 issue) and finaly DVD Player's quality of optics, if it is picky about media, firmware, if it does support media type +/-.....
Not all stand alone DVD players like DVD-R discs that come straight out of Panny stand alone DVD recorders.
I have two that play DVD-R discs made on a computer but not on a Panny stand alone.
The only work-around is to buy a player that does like it suc has a model by Panasonic (most of which also play DVD-RAM now as well) or re-author the disc on the computer which will solve the problem but that means either throwing away the original DVD-R or using DVD-RAM
Since you can buy a simple DVD-ROM drive that also reads DVD-RAM discs that would be the cheapest way of doing it. Import the DVD-RAM to the computer then make a custom DVD-R with your computer burner.
TMPGEnc DVD Author is great for doing this.
Video to iMovie from Panasonic DMR E80H
By cjc182 in forum MacReplies: 0Last Post: 20th Jan 2012, 19:20 -
Panasonic DMR-E80H issue
By mavphoto in forum DVD & Blu-ray RecordersReplies: 3Last Post: 8th Jun 2010, 19:10 -
Panasonic DMR-E80H Error messages
By JeffM in forum DVD & Blu-ray RecordersReplies: 38Last Post: 7th Oct 2009, 17:08 -
Panasonic DMR-E80H Setup
By thebrookela in forum DVD & Blu-ray RecordersReplies: 7Last Post: 24th Mar 2009, 14:37 -
Panasonic DMR E80H problem when recording..
By Gravelexpress in forum DVD & Blu-ray RecordersReplies: 1Last Post: 27th May 2008, 09:36
