EDIT: Known problem, should have searched first, sorry
Created a DVDR project that is a tad too big (6.4 gb) want to transcode down to compliant size, but the files cannot be opened in DVDShrink 3.0 beta 5 I get the error, "Cannot decrypt VOBS reason unknown." Works fine using DVD Shrink 2.3. Anybody else come across this problem?
Thread: Ignore This
I get the same problem when i make the files with tmpgenc dvd author,i rather use dvdshrink 3.0 beta for the deep analysis for shrinking my files further so what i do is after making the files with tmpgenc dvd author i then make an iso with the writing tools section and then mount the iso with a virtual cd/dvd such as alcohol 120% and daemon tools give you,then i can get dvdshrink to open the virtual dvd and shrink with no error message.
please ignore-reposting
By clancey in forum CapturingReplies: 2Last Post: 2nd Nov 2009, 12:16 -
SVCD Cant Register (FIXED - Please ignore)
By Gezzerboy in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 30th Dec 2008, 10:15 -
test - ignore and delete
By glinscott in forum TestReplies: 3Last Post: 19th Sep 2008, 03:20
Statistics
Newest guides
Latest tool updates
New media comments
