VideoHelp.com Forum
Results 1 to 9 of 9
  1. **if this is in the wrong forum, i apologize**
    okay, i'm trying to write a ripped dvd movie with pinnacle instantcopy. thing is, when it gets to 100% and it's writing the leadout track (i assume) i get an error message.
    it says "hardware error: write 32765 bytes at postion 2295104
    error info: the disc application layer has issued that the drive does not support." then it tells me that if there's still a problem to write in TAO, DAO, or RAW writing. then it says
    sense info: 70 00 05 00.....
    command: 7a 00 00 23......
    i have a sony dru510a and it's fairly new. this is the first error i got. i tried it twice, and i still got the same error, so it's not a one-time thing. i also burned a couple other movies in between those 2 so i know there's not a problem with the burner. i used khypermedia+r's. i've used them before, and as i said before, i had no errors. so do i need to change the media (i also got tdk-r's), should i maybe reduce the quality a littlebit so that it's under 4.31, or should i maybe update the firmware (i didn't do it since it's been working fine. thanks in advance for any help
  2. VH Veteran jimmalenko's Avatar
    Right you are, its a two-time thing !
    Just kidding.
    The media and/or the firmware are most likely to be the cause. The size should be OK - I have only heard of this working with some cheap media where the outer 5% of the discs are dodgy, but essentially it is because the media is crap to start with.
    Try some different media and also look for firmware updates. Look for updates with your software and/or try other burning software. It might just be a matter of two things not liking each other with your current config.
    If in doubt, Google it.
  3. Originally Posted by jimmalenko
    Just kidding.
    if anything, i think it's more like the media. i don't think it's so much as the firmware/software cuz i've burned about 10 movies, all different sizes and didn't have any problem
  4. VH Veteran jimmalenko's Avatar
    Could be right. Some media often have a sprinkling of bad discs throughout.
  5. well, i retried. this time i did a firmware update and used a tdk-r. still same error at the same time with the same info except this time it said that the compilation size exceeded the disc size. that's weird now cuz instant copy always automatically shrinks it. i never had a problem, only with this particular movie. do i maybe need to shrink it down some more? in that case, how do i do it with instantcopy cuz even when i lower the quality, it always goes to 4.31G no matter what
  6. well, i retried yet again. this time i reduced the size to about 4.06 and it still gave me the error at the same place. someone please help me. should i maybe do what the message said and try DAO, TAO? but i don't even know what those are.
    You need to try differant software. Maybe dvd2one or dvd shrink. Then use anything but nero to burn the disk.
    make sure you have the correct aspi layer, i had the same problem with nero, i found out a different program i had put on my computer messed up my aspi, corrected it with force aspi
  1. a disk error occurred during a write operation
    By SE14man in forum Computer
    Last Post: 8th Nov 2011, 01:16
  2. Write error problem with mpeg streamclip
    By mattcourage in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 8th Nov 2008, 10:57
  3. Can a 4x burner write to a 16x disc?
    By bobarnett in forum DVD & Blu-ray Recorders
    Last Post: 24th Sep 2008, 15:47
  4. write 2 movies in 1 disc
    By akakiami in forum DVD Ripping
    Last Post: 10th Sep 2008, 07:06
  5. Pioneer 420H - Can't Write Data Error
    By cie3 in forum DVD & Blu-ray Recorders
    Last Post: 23rd May 2007, 22:51
