Camcorder format which allows you to record digital-quality video onto standard Hi8 or 8mm tape. Most Digital8 camcorders also play back analog Hi8 and 8mm recordings, although they do not record in Hi8 or 8mm. A 120-minute Hi8/8mm tape yields one hour of recording when used with a Digital8 camcorder, giving you essentially the same stunning picture quality as you get with Mini DV (500 lines of horizontal resolution).
Thread: Digital8
That being said...
What is the best way to capture the video on a Dig8 tape to PC?
install firewire Card and start out with something simple like
Ulead Videostudio 6 or 7
then as you get better move up to Adobe premiere or vegas video\Sony
Try to use the tracks view instead of the filmstrip view.. you will learn more about editing that way.. good Luck
I like D8 myself (having 3 cams). But some of that is misleading. "digital quality" means absolutely nothing. VCDs are "digital quality". For that matter, low bit rate Windows media are, too. Now, if you meant "DV quality", fair enough. But that's still no standard. D8 cams are as good IMO as cheap DV cams in the same price range, but neither matches a VX2000, and they're all supposdly "DV quality". It's all about optics & CCDs. Few cheapies get all 500 lines of res through their optics.Originally Posted by Baldrick
Reading 8 mm and HI8 tapes in Digital8?
By tentate in forum Camcorders (DV/HDV/AVCHD)Replies: 19Last Post: 28th Dec 2009, 10:58 -
Digital8 to DVD Quality Issue?
By robbieturner in forum Authoring (DVD)Replies: 12Last Post: 8th Sep 2009, 05:23 -
Sony Digital8 Camcorders
By k2skier in forum Newbie / General discussionsReplies: 1Last Post: 15th Jan 2009, 13:10 -
Erasing Digital8 tapes
By skieffer in forum Camcorders (DV/HDV/AVCHD)Replies: 2Last Post: 8th Jan 2009, 12:24 -
Using Canopus with Digital8 Camcorder...
By guber in forum CapturingReplies: 2Last Post: 4th Jan 2008, 14:19
Statistics
Newest guides
Latest tool updates
New media comments
