VideoHelp.com Forum
    HI,
    I have a set of dvd's which contain information regarding parts and service infomration for certain industrial machines. There are seven dvd's and they were quite expensive to buy from the manufacturer. As i use the DVD's every day i want to back them up so that if one becomes damaged i have a spare. I have recently bought an lg multiwriter and nero 6. The problem i am facing is this. When i go to add the files from the dvd to a new data dvd on nero, it appears that there is over 7gb of data on the dvd. When i saw this i went into mycomputer on win xp and i rightclicked on the drive and selected properties. It said there was 7.7gb of information on the disc. I have looked around on the internet and i cannot find anywhere thast sells dvd's that hold that much. The dvd's were made in 2001 and so i cant believe that the dvd's could be a new technology. Can anybody help? could this be some sort of copyright protection. Most of the infomration is either .tif files or text. There is a very large amount ue to the amount of machinery the firm manufacture. Any help would be extremely helpful,
    Thanks.
    George Sly
    the dvd's you are trying to back up are dvd9. you can only burn to dvd5 now. you will have to split the disk or shrink them to make them fit.
    HI again,
    So is there no way of buying and writing to dvd-9 at present?
    Thanks,
    George
  4. Member Craig Tucker's Avatar
    Originally Posted by gsly997
    HI again,
    Thanks,
    George
    No, DVD9's have 2 layers of data (dual layer). It is only possible to burn to single layer discs at the moment.
  5. Wait about 6 months to a year and you can burn disk to disk 1:1 copies, but as for now you'll have to split the data on two disks
  1. Blu Ray and burning a Data Disc...not a Video Disc
    By Moontrash in forum DVD & Blu-ray Writers
    Last Post: 26th Dec 2011, 16:18
  2. Copping Disc - Disc Data Recovery Software.
    By Teac23 in forum DVD Ripping
    Last Post: 1st Oct 2010, 20:06
  3. New DVD to hold 2000 movies on 1 disc
    By Rudyard in forum Latest Video News
    Last Post: 8th Nov 2009, 06:10
  4. Steps to convert BDMV to AVCHD: data disc problem with PS3
    By devilcoelhodog in forum Authoring (Blu-ray)
    Last Post: 12th Jan 2009, 18:53
  5. "Data Disc DVD" Audio Problem
    By U87 in forum DVD & Blu-ray Players
    Last Post: 17th Jan 2008, 10:24
