Okay, when you compile an audio cd, usually under the pause section it says 2 seconds. How do I change that?
thanks
"Be excellent to each other." - Ted Theodore Logan
Make sure you're burning in Disc At Once mode and select every track, then hit properties, and set it to ZERO. Then click BURN. It will tell you it needs to adjust the first tracks pause because it goes against the standard, then hit OK and you should be good to go. No pauses.
Player pauses
By Daijard in forum Software PlayingReplies: 8Last Post: 9th Feb 2010, 20:53 -
how to record without pauses
By mehrlicht in forum DVD & Blu-ray RecordersReplies: 2Last Post: 9th Apr 2009, 16:00 -
Help : Nero Problem / Transition Pauses !
By porkys1982 in forum EditingReplies: 4Last Post: 6th Oct 2007, 22:33
Statistics
Newest guides
Latest tool updates
New media comments
