VideoHelp.com Forum
  1. I built my computer a couple years ago and it's considered a dinosaur now. I'm not sure if it can handle a DVD burner. Can a PIII 733 processor with 639mb ram handle a DVD burner?
    I plan on building a new computer a few months down the road, but would like to buy the dvd burner now if it'll work with what I currently have.
  2. Hello Ladies stiltman's Avatar
    not sure of the OS or the HDD space
    BUT a PIII or a PII can handel a DVD burner
    What do you want to do with it?
    Originally Posted by jagabo
  3. Running one on a duron 750 with 512 ram. Mind you its all it does is rip and burn and never at the same time.
    So long as you have a good bit od H/D space to work with you will be OK, unless you only have a small power supply and already have lots of drain on it already.
    Not bothered by small problems...
    Spend a night alone with a mosquito
  4. That sounds like good news to me! I have plenty of HD space. I actually just installed a second HD recently. I still run Win98se. I know I have a file size limit, but I can work around it until I upgrade to WinXP. I just wanted to make sure it could burn dvd's without errors.
    I'll use it to backup some dvd's but my main use will be to put digital camcorder movies on dvd and copying other dvd-r or dvd+r. I've been using svcd and vcd format for a while but can't take it anymore!
  5. Hi,
    I bought a Sony DRU-510A burner to be put in a new system; but it can't be built for another month. Will it work if I put it in my older PII machines for now and back up data? I have a PII 400 with 1GB of memory, and a dual PII 350 with 512 MB of ram, both running Win2K Pro. The Sony box says minimum system requirement is PII 400; but recommended system is a PIII... And the data is actually stored on the dual PII 350. Any thoughts?
    Thanks in advance...
    Spiffy
  6. Why not give it a try can only waste a disk if it dont work. I would try to close as many background apps as possible so burner can hog all resources it needs.
    Min Specs properly relate to software provided rather then the drive its self.
  1. Replies: 12
    Last Post: 24th Jul 2011, 20:27
  2. Will this computer handle the BMIP?
    By WILDWAYNE001 in forum Newbie / General discussions
    Last Post: 10th Nov 2010, 19:46
  3. sata dvd burner in older computer
    By victoriabears in forum DVD & Blu-ray Writers
    Last Post: 1st Apr 2010, 01:28
  4. Need a new DVD burner for my new computer.
    By usually_quiet in forum DVD & Blu-ray Writers
    Last Post: 20th Oct 2009, 15:04
  5. Replies: 44
    Last Post: 9th May 2007, 08:31
