Hello,
I use ATI AIW TV-tuner (MMC 8.7) to capture video but in the final file, I can't hear the audio (while at capture I can). Its seems that there is a easy fix for this, but I can't find it. Can anybody help me out?
Thanks!
Thread: Can't hear audio after capture
Verify that the audio cable is properly connected from the AIW to the sound card, this is the most common failure. Also that the recording source is properly set (line-in is best), and that the volume setting for recording in windows is not muted.
Thanks for the reply!
The sound cable from VideoOUT of AIW Radeon goes to Line-in of SoundblasterLive.
Using VirtualVCR, I found out that the sound comes from CD-Audio not Line-In (when I switch sound source from line-in to cd-audio, I can hear the audio in recorded file).
What exactly is going on here?
It really depends on how your sound card labels the inputs compared to how Windows labels them in the sound properties in the control panel. The 1/8" jack at the back of your sound card should be line-in and the internal 4-pin jack on your sound card should be cd-in. It really shouldn't matter though. You found which input needs to be unmuted. Just leave it at that.
But is the problem is that ATI's MMC 8.7 cannot be configured for audio input (or can it?), so the files it captures are without sound. Is there is anything I can do in windows to tweak it around?
Thanks.
Can't hear audio on PS3 from AVI (specs included)
By bound4h in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jul 2010, 14:49 -
WinDV - Hear sound during capture?
By scormodo in forum CapturingReplies: 1Last Post: 20th Mar 2010, 10:41 -
Cannot Hear Audio on AVI
By Squid_uk in forum Newbie / General discussionsReplies: 4Last Post: 25th Sep 2008, 09:05 -
If I connect my HDTV to my PC, will I be able to hear DTS audio?
By oleglelchuk in forum Newbie / General discussionsReplies: 37Last Post: 23rd Apr 2008, 09:03 -
RM to AVI can hear audio, but no video play
By Euphoria in forum ffmpegX general discussionReplies: 1Last Post: 9th Aug 2007, 18:28
