I bought a new computer a few months ago that came with a CD-RW/DVD+RW/R writer. It is a HP 300n DVD writer. I can't find anywhere in the specs for the DVD or in the guide that came with the computer what speed it reads and writes at. And I can't even find that model on HP's website. The reason I want to know this is because I bought a 25 pack of Memorex DVD+R last week and when I tried to burn a DVD on one of the disks it didn't work. I noticed there was a warning that came in the package that said something about upgrading the firmware if your DVD writer writes at less than 4x. Since I don't know what the speed is on mine, I don't know if I need to upgrade. Does anyone know how to check the speed on my writer?
Thread: read/write speed?
From this page on HP's site:
http://h20015.www2.hp.com/hub_search...Name=c00001838
It appears that your drive is actually the 300i drive. It just reports itself as a HP DVD Writer 300n to your system. The 300i appears to write DVD+R at 4x and DVD+RW at 2.4x. It don't own this drive, so I'm just going by what I see on their site.
Thanks a lot for your help!
Another question... so if my DVD writer writes at 4x then why did the DVD I burned on the Memorex DVD not work? I usually use Sony DVD+R and have also used TDK before also. Both of these are also for 4x speed writers.
so i presume with other media you're not having problems? some of the recent memorex is bad media that won't properly burn (power calibration errors) at 4x and needs to be burned at 2.4 (very lame, i know) .
multi LG Gh22np20 write speed issues
By mistermofo in forum DVD & Blu-ray WritersReplies: 5Last Post: 6th Jan 2010, 18:37 -
Read/Write at the same time
By mis3 in forum DVD & Blu-ray WritersReplies: 10Last Post: 22nd Oct 2009, 10:29 -
Finding out write speed
By BrokenOne in forum DVD & Blu-ray WritersReplies: 2Last Post: 31st May 2008, 01:40 -
DVD burner read/write speeds
By ecc in forum Authoring (DVD)Replies: 9Last Post: 13th Apr 2008, 05:49 -
problem with write speed of dvd burner`
By mr-scarface in forum DVD & Blu-ray WritersReplies: 4Last Post: 20th Sep 2007, 12:58
