When DVD Shrink first reads a DVD it must create a temp file because after the file is created, it doesn't have to read that DVD again before it didplays it's main window. I was wondering if anyone knows where those temporary files are stored. I am curious as to how much space they take up and if I can/should delete them.
Thanks!
-Matt
dj matty b
They're stored somewhere in the Documents and Settings folder (Win XP). I'd have to check and see exactly where in that folder, but they're fairly small and I wouldn't worry about deleting them until you've done several hundred DVDs (even then they're insignificant compared to the temporary files on Internet Explorer and other programs that use temp files).
Thanks! You guys are great. I have 112 files in my temporary folder and they take up a total of about 6 megabytes so I think I'll just leave them in there.
-Mattdj matty b
ffmpegX to PSP conversion creates unreadable, Zero KB files
By Peter Sarkisian in forum ffmpegX general discussionReplies: 5Last Post: 15th Feb 2010, 11:06 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
why does sub2divx creates very small video files
By amtemp in forum SubtitleReplies: 1Last Post: 21st Sep 2008, 05:16 -
It creates empty files!
By aquasonic in forum ffmpegX general discussionReplies: 15Last Post: 12th Sep 2007, 17:01 -
Video and audio files are split in temp. file
By SSH1968 in forum Newbie / General discussionsReplies: 9Last Post: 14th May 2007, 17:50
