My problem: DVD+RW discs recorded on my new GoVideo R6530 DVD+RW set-top recorder freeze up my PC when I try to access them in Explorer.
This is when I just try to *look* at the contents. It happens both on Windows ME and XP machines, and with both the OEM disc and with a TDK of my own. As soon as I click on the DVD drive icon, the PC goes dead -- no keyboard, no mouse, no chance of a warm reboot.
Also, neither Nero or Prassi can reformat these DVD+RWs -- they just spit 'em out with errors.
The discs themselves are not corrupt. The TDK, at least, had PC content on it before being erased to record video.
Anyone else have a similar experience? And is there anything I can do to copy files from these DVDs to my PC?
(The unit does perform its primary function -- recording TV shows -- satrisfactorily, I should add.)
Results 1 to 16 of 16
hi, i got the Phillips DVDR70, i can rip the disc with dvd decrypter onto my hard DD, but my problem is DVDSHRINK cant read the files.
i was wondering what sort of files do DVD recorders record?
I don't understand why you would want to use DVDShrink on a DVD recordable since you don't have to compress or transcode it to fit on to a single DVD since it comes from a single DVD.Originally Posted by jinky
I've had trouble ripping them too sometimes. Usually works in IFO STREAM PROCESSING mode for me (that would be using DVD DECRYPTER).
thanks i,ll try IFO STREAM PROCESSING mode.
i use DVDSHRINK to edit out the adverts and to put 2 movies on 1 disc.
Why?Originally Posted by jinky
because you are that cheap?
stream processing mode creates a M2V file for the VIDEO and an AC-3 file for the AUDIO so that won't work (to the best of my knowledge) with DVDShrink.
ok your right im cheap, so do u mind telling me what prog will do it for me master?
wow 1766 posts, do u get out much?
One has to do what one has to do to catch up to TGPO although I doubt that will ever happen heheheOriginally Posted by jinky
BTW don't be "dense" and use your head. Author the ripped M2V and AC-3 then use DVDShrink on that although that is a horrible way of doing compression on already compressed captures JUST to fit more stuff on a DVD but hey whatever it's your eyesight.
I hardly dare ask, bbbbut what do i author the ripped M2V and AC-3
with? (not a very good stutter)
Despite the fact that you only have very few posts under your belt you HAVE been registered here for a long time now.Originally Posted by jinky
I cannot imagine you don't know the answer to this and if you really don't ... it's just plain sad.
Look here if you must:
http://www.dvdrhelp.com/tools?section=2#2
I'll say good luck since you apparently need it badly!
You've been out in the sun again Fulcilves, I can tellOriginally Posted by FulciLives"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
The reason he is trying to use DVDShrink is:Originally Posted by FulciLives
To use the "Start - End" function to edit out the commercials...then have DVDShrink re-author it for him. GOOD idea on paper....it's a shame that DVDShrink hates discs created in set-top recorders.
Are YOU that dense that you can't figure out what he is trying to do? You sure give us people from Pittsburgh a bad name quite often here don't you?
Use clonedvd to made acopy then use dvd shrink.I just try it out and it works.
thanks jimmy it work's great.
If i record one on a standalone dvd player ..dvdrw+ then make a clone of that with clonedvd it will let me rip it and make a new menus etc???
DVD region settings are a joke, I can't believe how stupid people are falling for it
When I made my first dvd with my Sansui -RW I formated the disk in VR mode and finalized it when done but my pc would not read it. Then I reformated the dvd in Video mode and made the dvd. My computer read the dvd with no problem. I don't know if this is your problem but it's something to check.
TV Settop box to DVD
By Quickshot in forum Newbie / General discussionsReplies: 4Last Post: 10th Aug 2010, 08:00 -
DVD Fab - DVD Shrink - DVD Decrypter OK, and disc is unusable?
By dledm in forum DVD RippingReplies: 7Last Post: 1st Jun 2010, 14:54 -
Windows 7 Upgrade Makes Some PCs Unusable
By deadrats in forum ComputerReplies: 88Last Post: 5th Dec 2009, 04:14 -
Making a compliant DVD for settop players?
By hopealaska in forum Video ConversionReplies: 5Last Post: 6th May 2007, 18:08 -
Convert movies for a settop DVD player?
By harleytio in forum Newbie / General discussionsReplies: 4Last Post: 6th May 2007, 16:05
